I am finding the exact same thing with my IP150 too.
My SP6000 firmware is 5.19.
My IP150 firmware is 1.39.02, hardware 020
I am also wondering why the MQTT never work for me.
Hi, anyone has any further development on this one?
Still trying to find out what is the firmware version of IP150 for those of you whose mqtt setup works.
Ciao @alfredo
I just discovered your add-on and Iâm trying to configure it.
My HW is:
SP6000
Firmware version 5.18
IP module 150
Firmware version 1.39.02
the IP150 port are different than standard, and I use SSL, so even if I go to http://paradoxip:xx it switches to https://paradoxip:yyy
where xx and yyy are different than standard 80 and 443
the addon configuration is
"IP150_ADDRESS": "http://192.168.0.23:xx",
"PANEL_CODE": "panelcode",
"PANEL_PASSWORD": "panelpasswd",
"MQTT_ADDRESS": "mqtt://core-mosquitto",
"MQTT_USERNAME": "mqtuser",
"MQTT_PASSWORD": "mqttpasswd",
"ALARM_PUBLISH_TOPIC": "paradox/alarm/state",
"ALARM_SUBSCRIBE_TOPIC": "paradox/alarm/cmnd",
"ZONE_PUBLISH_TOPIC": "paradox/zone/state",
"CTRL_PUBLISH_TOPIC": "paradox/ctrl/state",
"CTRL_SUBSCRIBE_TOPIC": "paradox/ctrl/cmnd"
Iâm using Hass.io latest version with included mqtt broker
Iâm getting these errors in log:
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
conn.connect()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 326, in connect
ssl_context=context)
File "/usr/lib/python3.6/site-packages/urllib3/util/ssl_.py", line 329, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.6/ssl.py", line 407, in wrap_socket
_context=self, _session=session)
File "/usr/lib/python3.6/ssl.py", line 814, in __init__
self.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 1068, in do_handshake
self._sslobj.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 689, in do_handshake
ssl.SSLEOFError: EOF occurred in violation of protocol (_ssl.c:777)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='192.168.0.23', port=421): Max retries exceeded with url: /login_page.html (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:777)'),))
File "ip150_mqtt.py", line 123, in <module>
ip_mqtt.loop_forever()
File "ip150_mqtt.py", line 105, in loop_forever
self.ip.login(self._cfg['PANEL_CODE'], self._cfg['PANEL_PASSWORD'])
File "/ip150.py", line 129, in login
'{}/login_page.html'.format(self.ip150url), verify=False)
File "/usr/lib/python3.6/site-packages/requests/api.py", line 72, in get
return request('get', url, params=params, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 506, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='192.168.0.23', port=421): Max retries exceeded with url: /login_page.html (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:777)'),))
probably since this error no sensors are shown.
Any suggestion on what Iâm doing wrong?
Ur MQTT u ask the driver to check @
âALARM_SUBSCRIBE_TOPICâ : âparadox/alarm/cmndâ,
You tell HASS to send to :
command_topic: âParadox/C/P1â
So your commands wont get executed by the driver
Very nice idea.
I am also trying to set it up, w/out much success.
Hi Guys
I seem to have got this working:
Please Like the post if this solves your problems
Running built in mqtt
configuration.yaml
mqtt:
broker: localhost
port: 1883
configuration.yaml
alarm_control_panel:
- platform: mqtt
state_topic: âparadox/alarm/state/1â
command_topic: âparadox/alarm/cmnd/1â
payload_disarm: âDISARMâ
payload_arm_home: âARM_HOMEâ
payload_arm_away: âARM_AWAYâ
#ARM_HOME = ARM_sleep @Line38 ip150.mqtt.py
configuration.yaml
- platform: mqtt
state_topic: âparadox/zone/state/2â
qos: 0
payload_on: âonâ
payload_off: âoffâ
Repeat for all your Zones/Openings and so forth
Hass.io: add-on details => Paradox IP150MQTT Adapter (web based configuration)
âIP150_ADDRESSâ: âhttp://[IP-OF-IP150]â,
âPANEL_CODEâ: â[mastercode]â,
âPANEL_PASSWORDâ: â[webpassword]â,
âMQTT_ADDRESSâ: âmqtt://core-mosquittoâ,
âMQTT_USERNAMEâ: âMQTT_userâ,
âMQTT_PASSWORDâ: âMQTT_pwdâ,
âALARM_PUBLISH_TOPICâ: âparadox/alarm/stateâ,
âALARM_SUBSCRIBE_TOPICâ: âparadox/alarm/cmndâ,
âZONE_PUBLISH_TOPICâ: âparadox/zone/stateâ,
âCTRL_PUBLISH_TOPICâ: âparadox/ctrl/stateâ,
âCTRL_SUBSCRIBE_TOPICâ: âparadox/ctrl/cmndâ
Hass.io: add-on details => Mosquitto broker (web based configuration)
âplainâ: true,
âsslâ: false,
âanonymousâ: true,
âloginsâ: ,
âcustomizeâ: {
âactiveâ: false,
âfolderâ: âmosquittoâ
âcertfileâ: âfullchain.pemâ,
âkeyfileâ: âprivkey.pemâ
Donât forget to Like the post
For the life of me I just canât seem to get this working!
tried so many different ways people have managed to get it to work but still no go
These are the errors I keeps getting
> Traceback (most recent call last): File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn (self.host, self.port), self.timeout, **extra_kw) File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection raise err File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection sock.connect(sa) ConnectionRefusedError: [Errno 111] Connection refused During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen chunked=chunked) File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 357, in _make_request conn.request(method, url, **httplib_request_kw) File "/usr/lib/python3.6/http/client.py", line 1239, in request self._send_request(method, url, body, headers, encode_chunked) File "/usr/lib/python3.6/http/client.py", line 1285, in _send_request self.endheaders(body, encode_chunked=encode_chunked) File "/usr/lib/python3.6/http/client.py", line 1234, in endheaders self._send_output(message_body, encode_chunked=encode_chunked) File "/usr/lib/python3.6/http/client.py", line 1026, in _send_output self.send(msg) File "/usr/lib/python3.6/http/client.py", line 964, in send self.connect() File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 166, in connect conn = self._new_conn() File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn self, "Failed to establish a new connection: %s" % e) urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x76134e30>: Failed to establish a new connection: [Errno 111] Connection refused During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send timeout=timeout File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen _stacktrace=sys.exc_info()[2]) File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment raise MaxRetryError(_pool, url, error or ResponseError(cause)) urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.2', port=80): Max retries exceeded with url: /login_page.html (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x76134e30>: Failed to establish a new connection: [Errno 111] Connection refused',)) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "ip150_mqtt.py", line 123, in <module> ip_mqtt.loop_forever() File "ip150_mqtt.py", line 105, in loop_forever self.ip.login(self._cfg['PANEL_CODE'], self._cfg['PANEL_PASSWORD']) File "/ip150.py", line 129, in login '{}/login_page.html'.format(self.ip150url), verify=False) File "/usr/lib/python3.6/site-packages/requests/api.py", line 72, in get return request('get', url, params=params, **kwargs) File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request return session.request(method=method, url=url, **kwargs) File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request resp = self.send(prep, **send_kwargs) File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send r = adapter.send(request, **kwargs) File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 508, in send raise ConnectionError(e, request=request) requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.2', port=80): Max retries exceeded with url: /login_page.html (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x76134e30>: Failed to establish a new connection: [Errno 111] Connection refused',))
Seems like some files just donât exist on my hassio. for example when I navigate to /usr/lib/python3.6/site-packages/urllib3/ I canât find connection.py
Your config is lacking for the ip for the IP150 => 192.168.1.2 ?
Max retries exceeded with url: /login_page.html (Caused by NewConnectionError(â<urllib3.connection.HTTPConnection object at 0x76134e30>: Failed to establish a new connection: [Errno 111] Connection refusedâ,))
I fixed it,
turned out that my IP150 was working on port 188. Logged in to web interface and changed it back to port 80
Now everything is working fine!
Iâm having too an error
chunked=chunked)
conn.connect()
self.do_handshake()
timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='192.168.1.xx', port=xxxx): Max retries exceeded with url: /login_page.html (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:777)'),))
requests.exceptions.SSLError: HTTPSConnectionPool(host='192.168.1.xx', port=xxxx): Max retries exceeded with url: /login_page.html (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:777)'),))
my config is:
"IP150_ADDRESS": "https://192.168.1.xx:xxxx",
"PANEL_CODE": "panel_code",
"PANEL_PASSWORD": "panel_password",
"MQTT_USERNAME": "mqtt_user",
"MQTT_PASSWORD": "mqtt_pwd",
On IP150 I have only HTTPS, if I try HTTP port it switches automatically to HTTPS
Any suggestion?
Hi Cybertza, this is what I have:
In configuration.yaml
- platform: mqtt
state_topic: "paradox/alarm/state/1"
command_topic: "paradox/alarm/cmnd/1"
payload_disarm: "DISARM"
payload_arm_home: "ARM_HOME"
payload_arm_away: "ARM_AWAY"
code: "1234"
- platform: mqtt
state_topic: "paradox/ctrl/state"
- platform: mqtt
state_topic: "paradox/zone/state/1"
qos: 0
payload_on: "on"
payload_off: "off"
- platform: mqtt
state_topic: "paradox/zone/state/2"
qos: 0
payload_on: "on"
payload_off: "off"
and in my Paradox IP150 MQTT Adapter
"IP150_ADDRESS": "http://192.168.1.8",
"PANEL_CODE": "1234",
"PANEL_PASSWORD": "PanelPassword",
"MQTT_USERNAME": "mqttbroker",
"MQTT_PASSWORD": "4567",
and in my mosquitto broker
"plain": true,
"ssl": false,
"anonymous": true,
"logins": [
"username": "mqttbroker",
"password": "4567"
"customize": {
"active": false,
"folder": "mosquitto"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
I still could not get this to work. What am I doing wrong?
Thanks!
Ok. After restarting the rpi twice in a row and restarting hassio multiple times, and I still donât know what actually happen, but hassio is now seeing the zone status of the various alarm zones.
Previously all I see is âoffâ but now some of the PIR zone is indicated to be âONâ but the weird thing is that it remains on all the time. For instance, it says my garage PIR is ON when there is no one there.
Reed switches status however seems to work okay.
Any ideas?
Hi guys. I am having issue with stability of the current configuration.
Everything is working fine except when the security system is under alarm. It get stuck and even restarting the paradox module it is not connected to the hassio. I have to wait at least two days to get everything up and running.
I think on the event of Alarm the ip150 sent a lot of messages to the mqtt broker and it is blocked for at least 48 hours. Of course it is only my suggestion because i can not find anything related on the network.
My question is there someone with the same problem when the system is under alarm?
Is there a status for Under Alarm?
Thanks for your help!
Everything seems to be working but I just canât control the alarm, no arm or disarm
Iâve put in my code in config.json, options.json and in configuration.yaml
I have an SP5500, could it be that itâs going to the wrong MQTT command topic?
My âAlarm Stateâ bubble is showing status without problems but the âHouse Paradoxâ bubble is always showing âunknownâ
Can someone please help?
Also same issue on my side.
Connection status is âconnectedâ. But all bubbles showing âunknownâ.
I have also SP5500 and IP150 v4x.
This evening i"ll postmy config, maybe someone can help
As far as i know the ip150 mudule is working only if the firmware version is 1.39 or 1.40 so i think ver. 4 wouldnât work.
I had the same issue with ver. 4 and i had to investigate the problem for a month when i found somewhere that paradox lock some features on the IP module from firmware ver. 3 and above.
Your only way is to find IP150 with firmware 1.39 (downgrades are not possible)
Hi Peter, thanks for answar.
I control it allready with babyware and insight app (itâs working good). It would be greate to integrate in Hassio like i have other stuf (jalousie, garage, doors), i only missing alarm inside.
Could you please give a link to where who says firmware 1.39 or 1.4?
I have 1.34 on mine and I can see everything but just canât seem to control the unit
Hi all;
So I have got this up and running. Iâll write a fuller update on what I did in a short while when i have some time. Pretty straightforward with what has been brought up above.
I think what is causing the alarm going off to lock up the system has to do with the way the software handles the alarm state in the paradox system. I purposefully triggered the alarm system so that i could see the behaviour and true to form the system worked perfectly even with the alarm pending state with the timer before the system goes off.
What happened then is that the alarm creates a historical alarm log which is what i think locks it up. Not sure why yet, but iâll look through it further. I reloaded the entire HASS but it still remained locked up. I tried to clear the alarm from the panel but it did not clear for some reason, still showing a historical message. I think that the timeout will occur in the next day or so and then iâll see if the system unlocks itself then.
A question though it why is the WAN IP Logger portion of the IP150 system not used. In theory this should push the logs out to a remote monitoring site like ADT or something. Perhaps we could use this instead to send through to the MQTT broker for the firmware which is not usable anymore.
