is it possible to parameterize min_temp e max_temp in climate component ?
# Full example configuration.yaml entry
climate:
- platform: generic_thermostat
heater: switch.study_heater
target_sensor: sensor.study_temperature
min_temp: 15
max_temp: 21
ac_mode: False
target_temp: 17
cold_tolerance: 0.3
hot_tolerance: 0
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
initial_operation_mode: “off”
away_temp: 16
I have many thermostat. So I want make a default file (for example default_climate.yaml), and to save min_temp and max_temp in default_climate.yaml. So, when I change min_temp and max_temp value, I update this parameter automatically for every thermostat.
Is it possible ?
