Dear Experts, what kind of parameters are where to set if using the Companion App. Wireguard would be the VPN Solution. Thank you
I am using Wireguard on an Android phone with the Home Assistant Companion App. There really are no parameters that I set up. Wireguard VPN connects you the local network where HA is running so it looks like you are running it locally. This means that any alerts will go directly to your phone.
The one thing I do set up is a tunnel over Wireguard so that only HA is routed over the VPN all the time. I don’t need all of my traffic from my phone going over the VPN unless I specifically switch that on. You can google how to set up a tunnel for specific apps. It’s fairly easy.
O.k. thank you. I triying get things fixed since 3 weeks without luck. Is there a detailed and easy instruction. I don´t miss this youtube gang. Just blending people but no instruction with all the details.
