trying to figure out how to plot parcels on a Map card.
Been using 17track sensor for a while and generally all good for status but I am not sure if/how to dynamically add the individual sensor.seventeentrack_package_xxx to a Map and further when manually adding a single sensor, how to I get it to pick up the location attribute?
You’d have to build an automation that takes the address/location and gets a lat/lon. Then you’d need to get that information into a device tracker.
The hard part would be finding something that turns an address into a lat/lon as this currently does not exist (to my knowledge) in home assistant. All current integrations go the other way. Lat/lon to address.
Then in order to make a device tracker, you’d need to use a python script or appdaemon to create a new device_tracker with the lat/lon as attributes so that it will appear on the map card.
