Parrot flower power
Hi
I have aa parrot flower that is correctly responding when using app from android ( first version)
My device is correctly detected by my android app
but I have an exceeded timeout value when dealing from HASSIO
I wander if it is possible to change the timeout value for such bluetooth sensors ?
I tried to modify the def value in the *.py but without success.
Tried also to put a timeout value in yaml without success
any Idea to fix it ?
extract of hassio log
(<Thread(SyncWorker_9, started 140511883033392)>) 2022-05-29 12:09:12 INFO (SyncWorker_0) [custom_components.parrotflowerpower.sensor] Polling data for FlowerPower HIDE Light Intensity 2022-05-29 12:09:12 INFO (SyncWorker_0) [custom_components.parrotflowerpower.parrotflowerpower_poller] Filling cache with new sensor data for device 90:03:B7:hide:hide:hide:hide. 2022-05-29 12:09:22 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.flowerpower_hide_light_intensity is taking over 10 seconds
Hi, I own one of these sensors too and Iā€™d like to use it with home assistant. May I ask which integration you are using?
here it is
ā€œGitHub - mbrentini/homeassistant_parrotflowerpower: Parrot Flower Power BLE sensor integration for Home Assistantā€
Thank you!
