I am trying to come up with a way how to parse data and create calendar events accordingly based on waste type.
My local garbage company has android app to notify for waste collection. Basically there are 3 types of garbage. I intercepted android app and it calls this URL to get the schedule:
This contains all events for year 2024. Basically what matters is wasteId and date - I just can’t figure out how to properly store the array and run calendar action for all array fields. Any help would be appreciated.
#configuration.yaml
rest_command:
get_waste_data:
url: "https://vylozsmeti.kabernet.sk/api/public/schedule?locationId=99&year={{now().year}}"
method: GET
Then use the response data in an automation or sensor. To populate the whole year’s events you can use a Repeat for Each action to iterate over all the items that are returned so they supply the data for the calendar.create_event action. Here’s a basic outline of the action sequence that would go in an automation or script:
- action: rest_command.get_waste_data
response_variable: waste
- repeat:
for_each: "{{ waste.content }}"
sequence:
- variables:
type: "{{ repeat.item.wasteType}}" #Should this return the type number or a description?
date: "{{ repeat.item.date | as_datetime }}"
- action: calendar.create_event
entity_id: calendar.EXAMPLE
summary: "{{ type }}"
# Do you want all-day events or not?
- delay: 2 #To keep the repeat from spamming the Calendar integration
If you can give a more specific description of how you want to construct the calendar events, we can give you more specific help with the automation.
I use a similar script for my trash calendar, though our collection company does not provide the dates so the templating is more complex. FWIW, I have a couple examples on my github (https://gist.github.com/Didgeridrew/491fa955ef2fe7c4f16bc503ac121db8) if you want to take a look at them.
Keep in mind that this doesn’t have any anti-duplication built in, so if you run it multiple times you will end up with multiple calendar events. Anti-duplication could be added by using the calendar.get_events action and then comparing dates, but I haven’t found it to be a problem with my instance.
This helped a lot. I moved a little further. I am OK with adding all day events, so I templated start and end date. This works fine and populates desired dates. However I would like to substitute wasteId with type, there are only 3 types:
2 - Generic Waste
5 - Paper
7 - Plastic
My script looks as follows, but it does not subsitute summary - I guess I am doing something stupid here:
But I am failing at comparing those in my condition - it always fails. I am not sure if template is the correct one. Idea is to only add event to calendar if it is matching my frequency (that I can define via dropdown).
In that case you can request it here: Sign in to GitHub · GitHub at “Source Request - Request that a municipality or region is supported”. It’s good that it’s a JSON API instead of some more complicated source (some garbage collection companies only offer rendered HTML pages).
