I cannot seem to find the correct term to use in my lambda. I’m parsing data that gives me output as JSON array.
The partial YAML looks like this:
http_request:
useragent: esphome/device
timeout: 10s
time:
- platform: sntp
on_time:
# Every 1 minutes
- seconds: 0
minutes: /1
then:
- http_request.get:
url: URL
headers:
Content-Type: application/json
Kommunenr: NUMBER
RenovasjonAppKey: API-KEY
OS: Android
Connection: Keep-Alive
Accept-Encoding: gzip
User-Agent: okhttp/3.2.0
verify_ssl: false
on_response:
then:
- lambda: |-
json::parse_json(id(http_request_data).get_string(), [](JsonObject root) {
id(test_output).publish_state(root[0].Tommedatoer[1]);
text_sensor:
platform: template
This is how the JSON output looks like:
[{"FraksjonId":1,"Tommedatoer":["2023-10-12T00:00:00","2023-11-09T00:00:00"]},{"FraksjonId":3,"Tommedatoer":["2023-10-12T00:00:00","2023-10-26T00:00:00"]},{"FraksjonId":2,"Tommedatoer":["2023-10-18T00:00:00","2023-11-15T00:00:00"]},{"FraksjonId":7,"Tommedatoer":["2023-10-18T00:00:00","2023-11-15T00:00:00"]},{"FraksjonId":4,"Tommedatoer":["2023-10-26T00:00:00","2023-11-23T00:00:00"]}]
I’m trying to fetch the data from each “FraksjonId”, i will primary be using the first date from within each FraksjonId, but i cannot seem to get the formating correct. I have successfully done a test with another JSON source, that are not array.
It is probably something that i’m missing. I appreciate all inputs to help me solve my issue.
