Hello to all!
I have a problem with parsing payload from MQTT. I have a device, which send it’s parameters to MQTT topic in this way:
$18 CE:0|CC:0|CO:0|CK:0|NC:0|SC:105|C1:255,255,255|DC:1|DD:3|DI:240|NP:1|NT:60|NZ:2|NS:[pool.ntp.org]|DW:1|OF:0|BR:100|PW:2200;
here is NAME:VALUE format. I’ve created some input_booleans, input_numbers and input_texts in HA to store this parameters. The length of this string depends from how many parameters were changed. Sometimes in can contain only 1 parameter, sometimes more.
I’m trying to create automation to parse this payload and put them into their input_***s
Here is my automation
- alias: Get Parameters
initial_state: true
platform: mqtt
topic: matrix/WiFiPanel-0/dta
- service: input_number.set_value
data_template: >
{% for i in range(0, 20) %}
{% if trigger.payload.split(" ")[1].split(";")[0].split("|")[i].split(":")[0] == "BR" %}
entity_id: input_number.matrix_brightness
value: '{{ trigger.payload.split(" ")[1].split(";")[0].split("|")[i].split(":")[1] }}'
{% elif trigger.payload.split(" ")[1].split(";")[0].split("|")[i].split(":")[0] == "PW" %}
entity_id: input_number.matrix_current_limit
{% else %}
{% endif %}
{% endfor %}
But it don’t work. The problem is, that it need also run different actions for boolean, number and text parameters. Is it even possible to get this working?
