ZippoSLO
(Marko)
February 24, 2023, 12:08pm
1
Hello!
What is the correct method to parse a string into a JSON and then get values from it? I tried many things, but nothind works - the value is always empty in the lambda section, but outside it is present.
on_response:
then:
- logger.log:
format: "Got REST response: %s"
args : ['id(http_request_data).get_string()']
- lambda: |-
ESP_LOGI("debug", "JSON get_string value:", id(http_request_data).get_string());
std::string data = id(http_request_data).get_string();
ESP_LOGI("debug", "JSON data value:", data);
Here’s the log
[12:44:15][D][wiegand:073]: received 26-bit tag: 3052795
[12:44:15][I][TAG:096]: received tag 3052795
[12:44:15][D][main:107]: Got REST response: {"USEROK":1}
[12:44:15][I][debug:114]: JSON get_string value:
I used the code provided in the EspHome article: HTTP Request — ESPHome (see the paragraph " GET values from a JSON body response").
The problem is that when logging the REST respone, the value is correct:
- logger.log:
is logged as
but when parsing in the lambda section, I always get an empty value in log, even if calling the same variable
is logged as
How to correctly pass the string value and then parse it?
ZippoSLO
(Marko)
February 25, 2023, 9:42pm
2
Nobody has this problem…?
petsie
February 27, 2023, 10:44am
3
I also had this with a chip: ESP32 - az-delivery-devkit-v4 .
It looks like this version does not work with the id (http_request_data).get_string ();
But if I save the request in a global variable or in a text sensor, I can process it.
ESP Version: 2023.2.4
## TEST id(http_request_data).get_string()
## board: az-delivery-devkit-v4; framework: arduino;
## platform: platformio/espressif32 @ 5.2.0
## 2023.2.4|Flash: 4096kB Speed:40MHz Mode:DIO|
## Chip: ESP32 Features:WIFI_BGN,BLE,BT, Cores:2 Revision:3|
## ESP-IDF: v4.4.2|EFuse MAC: 78:21:84:9C:B2:AC|
## Reset: Software Reset CPU|Wakeup: Unknown
substitutions:
device_name_short: "esp-ipinfo"
friendly_name: "IPInfo"
device_description: "Testcase for ip info"
domain: !secret domain
appversion: "2.0.1"
update_interval: "60s"
esp32:
framework:
type: arduino
esphome:
comment: "${device_description}"
build_path: ./build/${device_name_short}
## WIFI Settings
wifi:
networks:
- ssid: !secret ssid3_name
password: !secret ssid3_pswd
priority : 1
- ssid: !secret ssid1_name
password: !secret ssid1_pswd
priority : 2
- ssid: !secret ssid2_name
password: !secret ssid2_pswd
priority : 3
## WEBSERVER Settings
web_server:
port: 80
version: 2
local: true
## OTA Settings
ota:
password: !secret ota_pswd
on_error:
then:
- logger.log:
format: "OTA update error %d"
args: ["x"]
## Native API Component
api:
port: 6053
# The amount of time to wait before
# rebooting when no client connects to the API.
# Can be disabled by setting this to 0s
reboot_timeout: 0s
## Global variables
globals:
- id: ipInfodata
type: std::string
restore_value: no
initial_value: '""'
## Logger
logger:
level: info
baud_rate: 0 #disable logging over uart
## HTTP REQUEST HANDLER
http_request:
useragent: esphome/iptest
timeout: 10s
## Testcase
## http://ip-api.com/json/
## https://wasab.is/json
script:
- id: getNetInfoData
then:
- http_request.get:
url: http://ip-api.com/json/
headers:
Content-Type: application/json
verify_ssl: false
on_response:
- if:
condition:
lambda: |-
return status_code == 200;
then:
- logger.log:
level: info
format: "Response status: %d, Duration: %u ms"
args:
- status_code
- duration_ms
- lambda: |-
id(ipInfodata) = id(http_request_data).get_string();
- logger.log:
level: info
format: "Start telegramdata: %s"
args: ["id(telegraminfo).state.c_str()"]
# see: https://arduinojson.org/v6/assistant/#/step1
- lambda: |-
StaticJsonDocument<2048> doc;
DeserializationError error = deserializeJson(doc, id(ipInfodata));
if (error) {
ESP_LOGI("parse error", "deserializeJson failed %s",error.c_str());
}else{
const char* status = doc["status"]; // "success"
const char* country = doc["country"];
const char* countryCode = doc["countryCode"];
const char* region = doc["region"];
const char* regionName = doc["regionName"];
const char* city = doc["city"];
const char* zip = doc["zip"];
float lat = doc["lat"];
float lon = doc["lon"];
const char* timezone = doc["timezone"];
const char* isp = doc["isp"];
const char* org = doc["org"];
const char* as = doc["as"];
const char* query = doc["query"];
ESP_LOGI("IPInfo", "status %s",status);
ESP_LOGI("IPInfo", "city %s-%s",zip, city);
ESP_LOGI("IPInfo", "country %s",country);
ESP_LOGI("IPInfo", "regionName %s",regionName);
ESP_LOGI("IPInfo", "Coordinates: %.1f, %.1f",lat, lon);
ESP_LOGI("IPInfo", "timezone %s",timezone);
ESP_LOGI("IPInfo", "org %s",org);
ESP_LOGI("IPInfo", "provider %s",as);
ESP_LOGI("IPInfo", "Public IP %s",query);
## BUTTONS
button:
name: 'Test: IP Data'
on_press:
- script.execute: getNetInfoData
ZippoSLO
(Marko)
February 27, 2023, 1:29pm
4
Thank you, now works correctly via globals.
How can I inform the ESPHome team about this bug?
ZippoSLO
(Marko)
February 27, 2023, 1:49pm
5
I think it has already opened:
opened 12:21PM - 26 Feb 23 UTC
### The problem
StaticJsonDocument is empty
```json
"telegram": [
… "/ISk5MT174-0001",
"0.9.1(130203)",
"0.9.2(0230223)",
"0.0.0(00339188)",
"0.2.0(1.03)",
"C.1.6(FDF5)",
"1.8.1(0011404.409*kWh)",
"1.8.2(0023813.725*kWh)",
"2.8.1(0015608.962*kWh)",
"2.8.2(0000900.569*kWh)",
"F.F.0(0000000)",
Could not allocate memory for JSON document! Requested 0 bytes, free heap: 110580
1st log output shows the payload
2nd Error Could not allocate memory for JSON document
3rd log output shows no payload
### Which version of ESPHome has the issue?
2023.2.4
### What type of installation are you using?
Docker
### Which version of Home Assistant has the issue?
_No response_
### What platform are you using?
ESP32
### Board
### Component causing the issue
http_request
### Example YAML snippet
```yaml
## TEST ESPLESEKOPF TELEGRAMS
## board: az-delivery-devkit-v4; framework: arduino; platform: platformio/espressif32 @ 5.2.0
substitutions:
device_name_short: "esp-lesekopf2"
friendly_name: "Smartmeter"
device_description: "Smartmeter Device for Gridmeter ISKRA 2013 M13 1376, Drehstromzähler"
appversion: "2.0.1"
service_url: !secret service_host
service: "mt174.gridmeter"
## device configuration
board: "az-delivery-devkit-v4"
uart_rx_pin: "GPIO17" # white
uart_tx_pin: "GPIO16" # orange
uart_baudrate: "300"
esp32:
framework:
type: arduino
esphome:
## WIFI Settings
wifi:
networks:
priority : 1
priority : 2
priority : 3
web_server:
port: 80
version: 2
local: true
## OTA Settings
ota:
on_error:
then:
- logger.log:
args: ["x"]
api:
port: 6053
reboot_timeout: 0s
# Logger
logger:
level: info
# HTTP
http_request:
useragent: esphome/mt174test
timeout: 10s
# Serial interface
uart:
tx_pin: GPIO17 # white [TX] az-delivery-devkit-v4,
rx_pin: GPIO16 # orange [RX] az-delivery-devkit-v4,
baud_rate: 300
data_bits: 7
parity: EVEN
stop_bits: 1
rx_buffer_size: 512
debug:
direction: BOTH
after:
delimiter: "\r\n"
sequence:
- lambda: |-
UARTDebug::log_string(direction, bytes); //Still log the data
std::string str(bytes.begin(), bytes.end());
ESP_LOGI("UART", "DATA: %s",str.c_str());
## SCRIPTS
script:
- id: writeTelegram
parameters:
message: string
mode: queued
then:
- logger.log:
level: info
format: "Telegram message: %s"
args: ["message"]
- uart.write:
data: !lambda |-
std::string str = message;
std::vector<uint8_t> vec(str.begin(), str.end());
return vec;
- uart.write:
data: "\r\n"
- delay: 10ms
- logger.log: "Next Telegram message"
mode: queued
then:
- http_request.get:
headers:
verify_ssl: false
on_response:
- if:
condition:
lambda: |-
then:
- logger.log:
level: info
args:
- status_code
- duration_ms
- logger.log:
level: info
args: ["id(http_request_data).get_string()"]
- id: getTelegramdata
mode: queued
then:
- logger.log:
level: info
format: "HTTP Request get Data"
- http_request.get:
url: !secret data_host
headers:
verify_ssl: false
on_response:
- if:
condition:
lambda: |-
then:
- logger.log:
level: info
tag: "getTelegramdata"
args:
- status_code
- duration_ms
- logger.log:
level: info
format: "Response telegramdata: %s"
# {"telegram":
# "/ISk5MT174-0001",
# "0.9.1(130203)",
# "0.9.2(0230223)",
# "0.0.0(00339188)",
# "0.2.0(1.03)", "C.1.6(FDF5)",
# "1.8.1(0011404.409*kWh)",
# "1.8.2(0023813.725*kWh)",
# "2.8.1(0015608.962*kWh)",
# "2.8.2(0000900.569*kWh)",
# "F.F.0(0000000)", "!"
- lambda: |-
ESP_LOGI("script", "Decode Response");
json::parse_json(id(http_request_data).get_string(), [](JsonObject root) {
for (uint16_t i = 0; i < 12; i++) {
ESP_LOGI("parse", "telegram %d: %s",i,root["telegram"][i] );
- logger.log:
level: info
- logger.log:
level: info
format: "End telegram decoder"
- id: snddata
then:
- lambda: |-
uint16_t size = id(seltelegram).size();
for (uint16_t i = 0; i < size; i++) {
auto option = id(seltelegram).at(i);
auto value = option.value();
ESP_LOGI("script", "Option at %d is: %s", index, value.c_str());
id(writeTelegram).execute(value);
select:
name: "Select Telegram"
optimistic: true
options:
- "/ISk5MT174-0001"
- "0.9.1(130203)"
- "0.9.2(0230223)"
- "0.0.0(00339188)"
- "0.2.0(1.03)"
- "C.1.6(FDF5)"
- "1.8.1(0016519.075*kWh)"
- "1.8.2(0029595.323*kWh)"
- "2.8.1(0020656.624*kWh)"
- "F.F.0(0000000)"
on_value:
then:
- logger.log:
format: "Telegram Data: %s"
tag: "select"
args: ["x.c_str()"]
- lambda:
id(writeTelegram).execute(x.c_str());
## switches
switch:
- platform: restart
button:
name: 'Test: Get Telegram Data'
on_press:
- logger.log:
level: info
format: Get Data and decoder for telegram startet"
- script.execute: getTelegramdata
name: 'Test: Telegram Data'
on_press:
- logger.log:
level: info
format: "Simple Testcase"
- script.execute: snddata
on_press:
### Anything in the logs that might be useful for us?
```txt
[13:07:15][I][main:413]: Get Data and decoder for telegram startet"
[13:07:15][I][main:267]: HTTP Request get Data
[13:07:15][I][getTelegramdata:290]: Response status: 200, Duration: 48 ms
[13:07:15][I][getTelegramdata:293]: Response telegramdata: {"telegram": ["/ISk5MT174-0001", "0.9.1(130203)", "0.9.2(0230223)", "0.0.0(00339188)", "0.2.0(1.03)", "C.1.6(FDF5)", "1.8.1(0011404.409*kWh)", "1.8.2(0023813.725*kWh)", "2.8.1(0015608.962*kWh)", "2.8.2(0000900.569*kWh)", "F.F.0(0000000)", "!"]}
[13:07:15][I][script:314]: Decode Response
[13:07:15][E][json:081]: Could not allocate memory for JSON document! Requested 0 bytes, free heap: 110580
[13:07:15][I][getTelegramdata:322]: Response telegramdata: <-- 2nd Log output empty !
[13:07:15][I][getTelegramdata:325]: End telegram decoder
### Additional information
_No response_
jov
August 2, 2023, 12:15pm
6
This wasn’t the solution for me and I don’t think the real solution is to use globals. It looks like id(http_request_data).get_string()
returns an empty string after the first call.
This code:
ESP_LOGI(RESPONSE, get_string(): [%s], id(http_request_data).get_string());
std::string response_data = id(http_request_data).get_string();
ESP_LOGI(RESPONSE, response_data: [%s], response_data.c_str());
if (!response_data.empty()) {
ESP_LOGI("JSON", "Parse");
json::parse_json(response_data, [](JsonObject root) {
id(switch_x).publish_state(root["value"]);
produces this log:
[I][RESPONSE:055]: get_string(): [{"id":"sensor-switch_state","value":1,"state":"1.0"}]
[I][RESPONSE:057]: response_data: []
And if the first ESP_LOGI line is omitted:
[I][RESPONSE:056]: response_data: [{"id":"sensor-switch_state","value":1,"state":"1.0"}]
[I][JSON:058]: Parse
[D][sensor:094]: 'Switch': Sending state 1.00000 with 1 decimals of accuracy
