After trying for hours it gets me a headache. Getting my data from a tcp sensor. The data I receive looks like this
[{"path": "sdb", "model": "WDC WD30EZRX-00S", "temperature": 17.0}, {"path": "sda", "model": "Samsung SSD 840", "temperature": 14.0}]
I can’t even get to access values within the developer tools. However when I set the data manually there, it works as expected
{% set value_json = [{"path": "sdb", "model": "WDC WD30EZRX-00S", "temperature": 17.0}, {"path": "sda", "model": "Samsung SSD 840", "temperature": 14.0}] %}
{{ value_json[0]['path'] }}
{{ value_json[1]['temperature'] }}
But it does not when trying to use the data coming from the sensor. Maybe I just don’t see the issue anymore because of testing for hours and hours now.
{% set value_json2 = states('sensor.mysensor') %}
{{ value_json2[0]['path'] }}
It displays the data in the developer tools however:
{{ states('sensor.mysensor') }}
Error I get is
'str object' has no attribute 'path'
Would really appriciate any help from the pros here.
