Particle Photon through MQTT shows unavailable
This has been a great community and I have been reading to get my setup working.
Currently, I have a Particle Argon and was trying to use the following code from the following user/github and it seems the mqtt library was crashing it, being only written for the P0 Particle.
I have added my Mqtt username and password in my copy, since from what I have seen, the latest Mqtt requires this.
https://github.com/michaelusner/Photon-MQTT-Garage-Door-Controller/blob/b571918b482370f3dda9aa1760cdfe504d616dde/mqttGarage.ino
// MQTT garage door controller for use with Home Assistant
// Copyright 2020 - Michael Usner
// If you're fortunate enough to have 2 garage doors, you'll need to modify this code.
// TODO - configure via HTTP form
// This #include statement was automatically added by the Particle IDE.
#include <MQTT.h>
#define LOGGING
#define MQTT_CLIENT_NAME  "garage_controller"
#define MQTT_BROKER 192,168,1,9		// your broker IP here
#define MQTT_PORT 1883				// your broker port here
#define MQTT_USER "<user>"			// your broker user here
#define MQTT_PASSWORD "<pass>"		// your broker password here
#define MQTT_HASSIO_ONLINE_PAYLOAD  "online"
#define MQTT_HASSIO_STATUS_TOPIC    "homeassistant/status"
#define MQTT_DISCOVERY_TOPIC        "homeassistant/cover/garage/rollerdoor/config"
#define MQTT_AVAILABILITY_TOPIC     "homeassistant/cover/garage/rollerdoor/availability"
#define MQTT_COMMAND_TOPIC          "homeassistant/cover/garage/rollerdoor/set"
#define MQTT_STATE_TOPIC            "homeassistant/cover/garage/rollerdoor/state"
#define MQTT_OPEN_COMMAND           "open"
#define MQTT_CLOSE_COMMAND          "close"
#define MQTT_STOP_COMMAND           "stop"
#define MQTT_RECONNECT_MS 30000
#define MQTT_MESSAGE_SIZE 1024
#define OPEN_STATE      "open"
#define OPENING_STATE   "opening"
#define CLOSED_STATE     "closed"
#define CLOSING_STATE   "closing"
// get the device ID and use it in the device config payload
String deviceID = System.deviceID();
String deviceConfig = "{\"name\": \"Garage Door\", \"unique_id\": \"" + deviceID + "\", \"command_topic\": \"" + MQTT_COMMAND_TOPIC + "\", \"state_topic\": \"" + MQTT_STATE_TOPIC + "\", \"availability_topic\": \"" + MQTT_AVAILABILITY_TOPIC  + "\", \"retain\": true, \"payload_available\": \"online\", \"payload_not_available\": \"offline\", \"payload_open\":\"" + MQTT_OPEN_COMMAND + "\", \"payload_close\": \"" + MQTT_CLOSE_COMMAND + "\",  \"payload_stop\": \"" + MQTT_STOP_COMMAND + "\", \"state_open\": \"" + OPEN_STATE + "\", \"state_opening\": \"" + OPENING_STATE + "\", \"state_closed\": \"" + CLOSED_STATE + "\", \"state_closing\": \"" + CLOSING_STATE + "\", \"optimistic\": false, \"value_template\": \"{{ value }}\"}";
// Create the MQTT client
byte server[] = { MQTT_BROKER };
MQTT client(server, MQTT_PORT, mqttMessageReceived, MQTT_MESSAGE_SIZE);
// The relay pins.  Note that relay 2 is reserved for door 2 but is not in use here
int relay1 = D2;
int relay2 = D3;
// The magnetic switch pin
int magSwitch1 = D5;
// The magnetic switch status
int magStatus1 = 0;
int lastStatus = -1;
// This timer waits 20 seconds for the door to open or close
Timer waitForDoor(20000, refreshState, true);
// This timer is the polling loop for the magnetic switch
Timer pollMagSwitchTimer(500, pollSwitch, false);
// Poll the magnetic switch and set the state accordingly
// "lastStatus" is used to only send messages when the state has actually changed
void pollSwitch() {
    magStatus1 = digitalRead(magSwitch1);
    if (magStatus1 == HIGH && lastStatus != magStatus1) {
        setState("closed");
        lastStatus = magStatus1;
    } else if (magStatus1 == LOW && lastStatus != magStatus1) {
        setState("open");
// The MQTT 'message received' callback
void mqttMessageReceived(char* topic, byte* payload, unsigned int length) {
    char p[length + 1];
    memcpy(p, payload, length);
    p[length] = NULL;
    String message(p);
    payload[length] = '\0';
    String strTopic = String(topic).toLowerCase();
    String strPayload = String((char*)payload);
    Particle.publish("DEBUG", "MQTT message received on topic: " + strTopic + " : " + strPayload, PRIVATE);
	// process the message
	if (strTopic == MQTT_DISCOVERY_TOPIC) {
		// Home Assistant will send the payload back after the device discovery.
		// We use this as a signal to let HA know the device is available and to
		// update the state.
        sendAvailable();
        delay(1000);
        refreshState();
	} else if (strTopic == MQTT_HASSIO_STATUS_TOPIC && strPayload == MQTT_HASSIO_ONLINE_PAYLOAD) {
		// Home Assistant has restarted.  Trigger a device discovery to refresh.
        addDevice();
    } else if (strTopic == MQTT_COMMAND_TOPIC && strPayload == MQTT_OPEN_COMMAND) {
        openGarage();
    } else if (strTopic == MQTT_COMMAND_TOPIC && strPayload == MQTT_CLOSE_COMMAND) {
        closeGarage();
// Send a MQTT message to a topic
void sendMqttMessage(String topic, String message) {
    String msg = "Sending message to ";
    msg += topic + ": " + message;
    client.publish(topic, message);
// Send the "available" message to HA
void sendAvailable() {
    sendMqttMessage(MQTT_AVAILABILITY_TOPIC, MQTT_HASSIO_ONLINE_PAYLOAD);
// Add the device to HA triggering a 'discovery'
void addDevice() {
    sendMqttMessage(MQTT_DISCOVERY_TOPIC, deviceConfig);
// Remove this device from HA by sending an empty payload per the HA docs
void removeDevice() {
    sendMqttMessage(MQTT_DISCOVERY_TOPIC, "");
// Send a state message to HA
void setState(String state) {
    Particle.publish("DEBUG", "State: " + state, PRIVATE);
    sendMqttMessage(MQTT_STATE_TOPIC, state);
// Connect to the MQTT instance
void connectMQTT() {
    Particle.publish("DEBUG", "Connecting to MQTT broker", PRIVATE);
    client.connect(MQTT_CLIENT_NAME, MQTT_USER, MQTT_PASSWORD);
    client.subscribe(MQTT_HASSIO_STATUS_TOPIC);
    client.subscribe(MQTT_COMMAND_TOPIC);
    client.subscribe(MQTT_DISCOVERY_TOPIC);
// Refresh the door position state by reading the mag sensor and setting status
void refreshState() {
    if (magStatus1 == HIGH) {
        setState(CLOSED_STATE);
    } else if (magStatus1 == LOW) {
        setState(OPEN_STATE);
// setup the controller
void setup() {
    // configure the mag sensor
    pinMode(magSwitch1, INPUT_PULLDOWN);
    // configure the relays
    pinMode(relay1, OUTPUT);
    pinMode(relay2, OUTPUT);
    digitalWrite(relay1, HIGH);
    digitalWrite(relay2, HIGH);
	// connect and add the device
    connectMQTT();
    addDevice();
	// start the polling loop timer
    pollMagSwitchTimer.start();
// the main controller loop
void loop() {
	// wait for a message
    if (client.isConnected()) {
        client.loop();
    else // reconnect if we lost the connection
        Particle.publish("ERROR", "MQTT client disconnected.  Reconnecting in 30s", PRIVATE);
        delay(MQTT_RECONNECT_MS);
        connectMQTT();
// Determine if the door is closed by reading the switch,
// setting state, and returning the result
int isClosed() {
        return 1;
    } else {
        return 0;
// Open the door
int openGarage() {
    if (isClosed()) {
        setState(OPENING_STATE);
        digitalWrite(relay1, LOW);
        delay(1000);
        delay(1000);
        waitForDoor.start();
    } else {
        Particle.publish("DEBUG", "Garage is already open", PRIVATE);
        return 0;
    return 0;
// Close the door
int closeGarage() {
    if (!isClosed()) {
        setState(CLOSING_STATE);
        delay(1000);
        delay(1000);
    } else {
        Particle.publish("DEBUG", "Garage is already closed", PRIVATE);
        return 0;
    return 0;
While clunky, defining everything, instead of just writing it out, it turns out it works on the original Particle Photon P0 with no issues on flashing it.
My question is twofold:
  1. that it shows as unavailable in HA, using the following for the mqtt switch template:
    Screenshot 2022-11-19 202143
mqtt:
  cover:
     - unique_id: garage_controller
       command_topic: "homeassistant/cover/garage/rollerdoor/set"
       state_topic: "homeassistant/cover/garage/rollerdoor/state"
       availability:
        - topic: "homeassistant/cover/garage/rollerdoor/availability"
       qos: 0
       retain: true
       payload_open: "Open"
       payload_close: "Close"
       payload_stop: "Stop"
       state_open: "open"
       state_opening: "opening"
       state_closed: "closed"
       state_closing: "closing"
       payload_available: "online"
       payload_not_available: "offline"
       optimistic: false
       value_template: "{{ value.x }}"
  1. How would I tie this mqtt cover to use this custom card?
    https://community.home-assistant.io/t/custom-button-card/386807/9?
Thank you
Couldn’t get this to work so I went through nodered and got it working in about an hour.
