Pass entity to script?
I cannot get this to work. I want a tap action to run a script from the frontend, and the script to use the entity I pass to the script?
This is what I tried to do after some searching on the forums:
                tap_action:
                  action: call-service
                  service: script.volym_ner
                    entity: media_player.vardagsrum
And the script:
action: media_player.volume_set
metadata: {}
data_template:
  volume_level: |
    {{ state_attr(entity, 'volume_level') | float - 0.02 }}
What am I doing wrong here?
Where does it fail? Does the card’s tap_action fail to execute the script or fail to pass the value of entity to the script?
The script’s trace can reveal the answers.
I get this error:
must contain at least one of entity_id, device_id, area_id, floor_id, label_id.
I tried changing entity to entity_id but it still doesn’t work.
The media_player.volume_set action in your script should specify which media_player will have its volume set.
  entity_id: "{{ entity }}"
  volume_level: "{{ state_attr(entity, 'volume_level') | float - 0.02 }}"
Yes, but I want to pass the entity from the tap_action, otherwise I need to make duplicates of every script for each entity.
The example I posted supplies the action with whatever is passed by the tap_action. Only one script is needed to control the volume of any media_player.
