Hi!
I need to pass Air Quality parameters like PM2.5 PM10, NO, CO, etc that come from my existing Sensor in HA to Python Script, which calculates air quality index (AQI) and then passes the result to another (new) Sensor in HA.
I have experience of receiving Python script result and creating Sensor based on it, but can’t pass source parameter to Python script.
Instead ‘8.21’ I need to pass Sensor value that comes from HA.
and instead of ‘print’ I will input this parameter to HA in configuration.yaml like this with command_line platform:
Take a look at the docs here. You can pass values to the python script with adding a data block to your service call and then access the data in the script with data.get().
Have you confirmed the script works by running it from the command line? If it doesn’t work like that then it definitely won’t work when Home Assistant calls it.
I’m using HA under VM, so ‘python3’ cannot be executed via Terminal.
But I’m using another command_line platform python scripts in configuration.yaml and they work like a charm.
Collecting python-aqi
Downloading python-aqi-0.6.1.tar.gz (9.0 kB)
Building wheels for collected packages: python-aqi
Building wheel for python-aqi (setup.py): started
Building wheel for python-aqi (setup.py): finished with status 'done'
Created wheel for python-aqi: filename=python_aqi-0.6.1-py3-none-any.whl size=9658 sha256=eb713044c77bf4eab5b1b297461cda2ac2983c2d62d4c09280d144002b9fcadf
Stored in directory: /root/.cache/pip/wheels/84/94/36/104051f1ca3d29d15c76f6830f128253bb2d8440e99b83aa9b
Successfully built python-aqi
Installing collected packages: python-aqi
Successfully installed python-aqi-0.6.1
When I look into logs now I see the following:
2020-09-08 21:54:53 ERROR (SyncWorker_2) [homeassistant.components.command_line.sensor] Command failed: python3 /config/python_scripts/py-aqi.py 5.5
2020-09-08 21:54:55 ERROR (MainThread) [frontend.js.latest.202007160] http://hassio.local:8123/frontend_latest/chunk.cf565e41b8a8dce0642a.js:133:238 Uncaught TypeError: Cannot read property 'header' of null
2020-09-08 21:54:55 INFO (MainThread) [custom_components.freeathome.pfreeathome] thermostat device ABB700D44BF7/ch0000 current temp is 28.1
2020-09-08 21:55:02 WARNING (SyncWorker_0) [homeassistant.components.python_script] Warning loading script py-aqi.py: Line None: Prints, but never reads 'printed' variable.
2020-09-08 21:55:02 INFO (SyncWorker_0) [homeassistant.components.python_script] Executing py-aqi.py: {}
2020-09-08 21:55:02 ERROR (SyncWorker_0) [homeassistant.components.python_script.py-aqi.py] Error executing script: __import__ not found
File "/usr/src/homeassistant/homeassistant/components/python_script/__init__.py", line 205, in execute
exec(compiled.code, restricted_globals)
File "py-aqi.py", line 1, in <module>
ImportError: __import__ not found
It states that actual parameter of PM2.5 is passed to the script correctly, though it finds error in ‘import’.
I use another Python script where I imported ‘requests’ same way and it works perfectly.
What can be wrong now?
I’m puzzled because that error message appears to be from the python_script integration which runs in a sandboxed environment and disallows importing of any library. Only an external python script, executed from the command line (which is what the command_line sensor does), can import libraries.
Well, nevertheless it imported the ‘python-aqi’ library.
Repeated attempt to install ‘python’aqi’ via python_executor in HA results in message that it’s already installed…
And, as I mentioned, I am having several scripts running with ‘import requests’, that was installed same way.
Any other idea?
My test system uses Home Assistant Container so I had to install the python-aqi library within the homeassistant docker container. I used Portainer to login into the container’s command line interface where I ran pip install python-aqi.
In order to make it easier to test, I used an input_number
After restarting Home Assistant, here’s the result:
If I increase the input_number’s value (and wait for the sensor to poll) the sensor reports a new calculated value:
So it does work but, due to a difference that’s not apparent, it doesn’t work for you. All I can suggest is that you review and compare the differences (if any) between how I configured it and how you did.
Requirement already up-to-date: python-aqi in /data/venv/lib/python3.7/site-packages (0.6.1)
WARNING: You are using pip version 20.0.2; however, version 20.2.3 is available.
You should consider upgrading via the '/data/venv/bin/python3 -m pip install --upgrade pip' command.
72
So it works!
After removing ‘python-aqi’ from requirements of this Add-on (after Hassio reboots), it reverts back to message
ModuleNotFoundError: No module named 'aqi'
When launching the script manually from Python Executor.
Is this some kind of temporary installation of ‘python-aqi’ via Python Executor?
How can I install it permanently?
If you installed Home Assistant Supervised in a virtual machine, the python-aqi library must be installed in the homeassistant docker container. If you are installing the library in the host operating system, Home Assistant cannot access it.
The way I explained above, in the homeassistant docker container.
Once the library is installed in the homeassistant container, it will be available to Home Assistant. However, containers are temporary and are replaced when you upgrade Home Assistant. That means each time you perform an upgrade, you will have to re-install the python-aqi library.
I use Portainer to manage all the docker containers used by Home Assistant OS (and Home Assistant Supervised). Portainer allows me to open a console into the homeassistant container where I can run pip install python-aqi to install the library.
Portainer is available as an Add-on in Supervisor > Add-on Store > Home Assistant Community Add-ons > Portainer.
