Pass value as int from HA to ESPhome?
Hi guys :slight_smile:
I have passed a sensor from HA to my ESP home, it works fine, it shows up in the esp32 logs as expected. But when I try to use the value in my esp32, i get this fault:
Expected integer, but cannot parse id(“sdm_630_address0”).state as an integer.
It’s defined as an Int in HA.
This is the import:
  - platform: homeassistant
    entity_id: sensor.sdm630address0
This i where I try to use it:
modbus_server:
  - id: modbuserver
    uart_id: smartmetersim
    address: 2 # slave address
    holding_registers:
      - start_address: 0
        default: id("sdm_630_address0").state # default value of register
        number: 1
        on_read: return value;
I have also tried without .state and with ->state but same result.
Can anyone point me in the right direction? Thanks :slight_smile:
Is your sensor defined under sensor: and not text_sensor or other type?
Alternatively, if I have trouble trying to see what the sensor type? is, I use logging.
  - interval: 30s
    then:
      - logger.log:
          format: "sdm-630-address0 : %i"
          args: [ 'id(sdm_630_address0)' ]
If %i doesn’t work, try %.0f (for float) %s (for text).
I’m sure there is a better way, but this should work.
Also it might be that you are using double quotes … I’m reasonable sure that you don’t need them in the ‘setup’ part and only single quotes in the other part :slight_smile:
It was under text-sensor, but i have now moved it to sensor:
And
modbus_server:
  - id: modbuserver
    holding_registers:
      - start_address: 0
        default: int(id("sdm_630_address0").state) # default value of register
        number: 1
Still makes the same error,
default: id(“sdm_630_address0”).state is also tried.
If I paste your code under logging like this:
logger:
  level: VERBOSE #makes uart stream available in esphome logstream
  baud_rate: 0 #disable logging over uart
  - interval: 30s
    then:
      - logger.log:
I just get logging errors because im using uart.
modbus_server:
  - id: modbuserver
    holding_registers:
      - start_address: 0
        default: int(id('sdm_630_address0'.state)) # default value of register
        number: 1
All I changed there was the " to ’ , oh, I also moved a bracket.
I use (int)id(some_sensor) although, both may work :slight_smile:
I’m no expert btw, did I mention that?
interval:
  - interval: 1min
Interval doesn’t go under logger: it is it’s own component (but like you say you are using uart so it won’t work)
That didn’t work either, but the interval log gives this:
[21:20:24][D][main:261]: sdm-630-address0 : 1073429584
Without the interval inserted I get this:
[21:30:24][D][text_sensor:067]: 'sdm-630-address0': Sending state '231'
Which makes no sense to me, and no worries, I take all the input I can get, I’m new in this field :wink:
Yeah, I don’t know … but when you work it out, don’t forget to come back and let the rest of us know what you did :slight_smile:
Could it expect hex input perhaps? Just guessing.
Maybe, but it won’t solve my initial problem :slight_smile:
No one else?
Seems you need to start with !lambda in order to reference id’s.
Can you try this?
  default: !lambda return id('sdm_630_address0').state;
What does that mean?
modbus_server:
  - id: modbuserver
    holding_registers:
      - start_address: 0
        number: 1
Just gives me this error: “This option is not templatable!.”
This means you cannot dynamically set a value for default and have to set a fixed, static value.
Try with:
modbus_server:
  - id: modbuserver
    holding_registers:
      - start_address: 0
        default: 1
        number: 1
        on_read: |
           return int(id('sdm_630_address0').state);
