Markus99
(Mark)
February 25, 2020, 7:27pm
1
Trying to avoid building dozens of unique scripts and instead pass a variable to a script.
Current Script:
htd_update_sensor:
sequence:
- service: system_log.write
data_template:
message: "UPDATE SENSOR ON ZONE: {{ zone }} - switch.htd_pwr_zone{{ zone }}"
level: info
- condition: template
value_template: >-
{% set device = 'switch.htd_pwr_zone{{ zone }}' %}
{{ is_state( device, 'off') }}
- service: homeassistant.update_entity
data_template:
entity_id: >-
{% set prefix = 'sensor.htd_sensor_zone' %}
{{ prefix }}{{ zone }}
Testing by calling script in Developer Tools -> Services
The log write is showing the correct ‘device’ value `switch.htd_pwr_zone1’, the switch state = off:
but the condition is FAILING in the logs:
Running this in template editor (hard coding device value) shows True
Thoughts? Thx in advance!
@Markus99
Did you manage to figure out what the problem is with your script.
I am trying to achieve somewhat the same and I am stuck at the same point.
Markus99
(Mark)
October 20, 2020, 1:04pm
3
Someone updated that custom_component to work, so didn’t end up using that code. What are you trying to accomplish more specificially @matthijsv93 ?
I am trying to make an automation that sends a variable with the groupname of a group of lights when a wall switch is pressed. A script reads the variable containing the groupname and switches the corresponding lights off and on with different brighness based on the time of the day.
The automation:
- alias: 'Wandschakelaar Woonkamer 1'
platform: event
event_type: deconz_event
event_data:
event: 2002
service: script.light_toggle
group: 'keuken'
the script:
light_toggle:
alias: 'schakel groepen'
sequence:
- choose:
- conditions:
- condition: and
conditions:
value_template: >-
{% set device = 'group.{{ group }}' %}
{{ state(device, 'off') }}
- condition: sun
before: sunset
after: sunrise
before_offset: '0'
after_offset: '0'
sequence:
- service: light.turn_on
entity_id: 'group.{{ group }}'
brightness: 180
transition: 1
- conditions:
- condition: and
conditions:
value_template: >-
- condition: sun
before: sunrise
after: sunset
before_offset: '0'
after_offset: '0'
sequence:
brightness: 100
transition: 1
default:
brightness: 0
transition: 1
mode: single
I think the problem is with the use of a variable within the condition template
@Markus99
