I’ve seen that description_placeholders in FlowResult is a dictionary with signature [str, str] and the docs suggest that it’s for ‘detailed information about the step’. In code data from async_show_form() is injected back to the caller through this parameter. Is this data supposed to be shown to the user somehow or is it more for internal consumption?
If the earlier, how to use it to give the user a more detailed error message when adding the integration?
When _create_entry() fails I’m calling async_show_form() again passing it the extended error message with the error key of description_placeholders. However, I don’t see the error message showing in the frontend.
This is the outline of how I’m doing it:
async def _create_entry(description_placeholders):
try:
# setup the device
except Exception as error:
description_placeholders["error"] = str(error.args)
return None
async def async_step_user():
placeholders: dict[str, str] = {}
result = self._create_entry(
description_placeholders=placeholders
if result:
return result
return self.async_show_form(
Thanks, Mark. I’m passing a basic error message using errors as you do, but one of the reviewers of my PR suggested to include in description_placeholders a more detailed error description for the user.
Oh, ok now I understand. In the strings.json you need to have the param name as part of the text description in curly brackets. Then the value passed in description_placeholders will replace that.
Ie.
In strings.json
"error": {
"cannot_connect": "Failed to connect. {error_detail}"
