Passing parameters through multiple levels: Automation --> Script --> Shell Command
Hi All,
I am confused with the following sentence in this documentation: https://www.home-assistant.io/integrations/shell_command/
“Any service data passed into the service call to activate the shell command will be available as a variable within the template.”
To me this implies that if I call the script from an automation, and that script in turn calls the shell command, the shell command can use the variables that I passed to the script.
Allow me to illustrate with an example. I have a shell_command in configuration.yaml
shell_command:
    play_sound: /usr/bin/omxplayer /home/homeassistant/sounds/{{filename}}
If I call it from a script like so:
play_a_sound:
  alias: Play a sound from a file
  sequence:
  - delay: 00:00:02
  - data:
      filename: Ship_Bell.mp3
    service: shell_command.play_sound
it works fine, however, if I call it from an automation (first removing the filename from the script), like so:
  - data:
    service: script.play_a_sound
it no longer works. The filename parameter does not get passed down all the way to shell_command despite what it says in the documentation. Perhaps I am misunderstanding that sentence. Anyone has any ideas how to do this correctly?
Yes, at each level you need to pass it on:
automation:
  - service: script.play_a_sound
script:
  play_a_sound:
    sequence:
    - delay: 00:00:02
    - data_template:
        filename: "{{ filename }}"
