This is not related to passing values into a script or anything during runtime, it’s about “substitutions” during setup.
I use packages extensively and I’m trying to save on repeated code. What I’d like to do is to be able to declare some variables at the top of a package yaml and then include a bunch of templates like this:
package.node_anchors:
room_name: &room_name Living Room
room_id: &room_id living_room
climate_entity: &climate_entity climate.living_room
heater_output: &heater_output switch.living_room_heater
temperature_input: &temperature_input sensor.living_room_average_temperature
homeassistant:
customize:
common: &common
package: Climate
room: *room_name
climate: !include ../templates/package_climate/generic_thermostat.yaml
binary_sensor: !include ../templates/package_climate/binary_sensor.yaml
sensor: !include ../templates/package_climate/sensor.yaml
So this would be my climate_living_room.yaml and if I wanted to create the same entities for kitchen, I just duplicate this file and change the anchors. I figure if you’re technically advanced enough to help me here, you know what I’m trying to do so I won’t go into more details.
Following @thomasloven 's guide on GitHub, I have a basic understanding of node anchors and I thought I might be able to get away with the above.
I understand that yaml is not designed to do any of this, however I figure the !secrets
, !include
, etc are already a work-around and was wondering if anyone knows a way of accomplishing what I’m trying to achieve above.
The error I get with the above code is:
Error loading /config/configuration.yaml: found undefined alias 'room_name'
in "/config/packages/../templates/package_climate/generic_thermostat.yaml", line 2, column 11
Any help would be hugely appreciated,
John
