Passing variables from automation to script - not working as expected
Hi all,
I used the following automation to pass a variable to a script:
- alias: 'ESP32 MQTT holding button 0'
    platform: mqtt
    topic: esp32/button_hold_0
    payload: "on"
    - choose:
      - conditions:
        - condition: state
          entity_id: input_boolean.button_hold_0_toggle
          state: 'on'
        sequence:
          service: script.turn_on
            entity_id: script.dim_lounge_left
            variables:
              upOrDown: "1"
      - conditions:
        - condition: state
          state: 'off'
        sequence:
            variables:
              upOrDown: "-1"
It appears to work correctly and passed the value of 1.
The script is as follows:
dim_lounge_left:
    fields:
      upOrDown:
        description: "Dim lights up or down"
    sequence:
    - service: light.turn_on
        entity_id: light.lounge_left
        brightness:  "{{ (((state_attr('light.lounge_left', 'brightness'))|int) + (upOrDown|int)) }}"
    - service: system_log.write
      data_template:
          level: debug
          logger: my_debug
          message: "{{ (((state_attr('light.lounge_left', 'brightness'))|int) + (upOrDown|int)) }}"
    - service: script.turn_off
          entity_id: script.dim_lounge_left_runagain
    - service: script.turn_on
        variables:
          upOrDown: '{{ upOrDown }}'
dim_lounge_left_runagain:
    fields:
      upOrDown:
    sequence:
        variables:
Now, the problem is that the script is not actually adding 1 to the brightness. If I replace +(upOrDown|int) with +1 it works. I used the debug log to check that the upOrDown was actually 1, and it showed up as 1 in my log. Anyone know why this isn’t working?
What’s the goal here?
Because if it’s to increment/decrement brightness repeatedly, what are the alleged advantages of the approach you have chosen (scripts calling scripts) versus a simple repeat?
