Passing Variables from script
I am trying to integrate a script from Jeffery Stone (https://www.youtube.com/watch?v=ey8MoQUDsRM) on gathering all media players from a script. My script is as follows:
alias: get_room_services_single
sequence:
  - variables:
      room_services: |-
        {% set jarvis_speaker = states.media_player |
            selectattr('entity_id', 'in', area_entities(room)) |
            rejectattr('attributes.last_called', 'undefined') |
            map(attribute='entity_id') |
          list | first %}
        {"jarvis_speaker":"{{jarvis_speaker}}"}
  - stop: ok, Im done.
    response_variable: room_services
mode: single
If I go to Developer tools and run the script, it returns just fine.
However, when I try to call this from a test automation, it states that it fails becuase template value should be a string for dictionary value @ data[‘message’]
alias: Test Automation with Variables
description: ""
  - platform: state
    entity_id:
      - input_boolean.test_helper
    to: "on"
condition: []
  - service: script.get_room_services_single
    data: {}
  - service: notify.alexa_media
      message: This is a test
      target: {{ room_services.jarvis_speaker }}
    enabled: true
mode: single
I’m obviously missing something very simple here. My guess is I’m not addressing the directory value correctly but I can’t figure out what exactly to use. The script is setting the return value to jarvis_speaker isn’t it?
  1. Value for the room variable isn’t being supplied when the script is called in the automation.
  2. No quotes around template for target.
How in the world did I miss I wasn’t passing the room?
Your suggestions worked perfectly. Thank you!
