So, my first time passing variables to scripts is a bit frustrating! I think I’m nearly there, but not quite. Essentially I want to pass an entity ID and hvac_mode to a script to turn a radiator on and off from a switch
The entity ID part seems to be working, but whatever I try it always fires nothing, or always fires the first condition in my script only.
Here’s what I have:
Script:
alias: Script - Heating
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ hvac_mode == heat }}"
sequence:
- service: climate.set_temperature
metadata: {}
hvac_mode: heat
temperature: 22
entity_id: "{{ radiator }}"
- conditions:
value_template: "{{ hvac_mode == turn_off }}"
sequence:
- service: climate.set_hvac_mode
metadata: {}
hvac_mode: "off"
fields:
hvac_mode:
radiator:
selector:
entity: {}
Switch:
heating_test:
unique_id: id_hsw_0000
turn_on:
service: script.script_heating
radiator: climate.tado_smart_radiator_thermostat_va3632810752
variables:
hvac_mode: heat
turn_off:
variables:
hvac_mode: turn_off
friendly_name: "Heating Switch Test"
value_template: "{{ is_state('climate.tado_smart_radiator_thermostat_va3632810752', 'heat') }}"
With this the first condition (turn on) is fired for both the on and off, so it doesn’t appear to be picking up the hvac_mode variable correctly.
I’ve tried various combinations of quotes, with and without the “variables” option in the switch config and nothing seems to work. If I pass hvac_mode not as a variable (i.e. in the same way I’m passing radiator) then it doesn’t fire at all.
Any suggestions?
