thank you!
last question, and I promise I will not bother anymore for this topic
is:
my configuration has:
Xiaomi Honeywell BT smoke detector
- one in kitchen - next to the Raspberry Pi
- one in upper flor - the one I would need to connect with ESPhome/BLE Gateway -
Switch Bot BT button (using SwitchBot Integration)
- one in upper flor whcih is not connected at the moment because the BT signal does not get there)
While the Passive BLE Monitor integration will fix the Xiaomi Honeywell BT smoke detector in upper floor, it seems that I would need to have another ESP 32 for the SwithcBot - I have found the following integration/project to extend SwithcBot Range:
Question:
is there any way I can use only one ESP32 or I need to have two of them? (not about the price, but I am keen to have a "klean infra/setting/configuration
thank you all!
