Passive BLE monitor integration
ATC, BlueMaestro, Brifit, b-parasite, Govee, Inkbird, iNode, Kegtron, Moat, Oral-B, Qingping, Ruuvitag, SensorPush, Teltonika, Thermoplus, Xiaogui and Xiaomi (MiBeacon and Mi Scale) sensors and device tracking
This custom component is an alternative for the standard build in mitemp_bt integration and the Bluetooth LE Tracker integration that are available in Home Assistant. BLE monitor supports much more Bluetooth Low Energy (BLE) sensors than the build in integration. Unlike the original mitemp_bt integration, which is getting its data by polling the device with a default five-minute interval, this custom component is parsing the BLE packets payload that is constantly emitted by the sensors.
Advantage of this integration is that it doesn't affect the battery as much as the built-in integration. It also solves connection issues some people have with the standard integration (due to passivity and the ability to collect data from multiple bt-interfaces simultaneously). Read more in the FAQ .
BLE monitor also has the possibility to track BLE devices based on its MAC address or UUID. It will listen to incoming BLE advertisements for the devices that you have chosen to track.
Supported sensors
Xiaomi (MiBeacon format)
LYWSDCGQ, LYWSD02, LYWSD03MMC, XMWSDJ04MMC, MHO-C303, MHO-C401, JQJCY01YM, JTYJGD03MI, HHCCJCY01, HHCCJCY09, GCLS002, HHCCPOT002, WX08ZM, MCCGQ02HL, YM-K1501, V-SK152, SJWS01LM, MJYD02YL, MUE4094RT, RTCGQ02LM, MMC-T201-1
Yeelight (MiBeacon format)
YLAI003, YLYK01YL, YLYK01YL-VENFAN, YLYK01YL-FANRC, YLYB01YL-BHFRC, YLKG07YL, YLKG08YL
Linptech (MiBeacon format)
K9B switch
Qingping (Qingping and/or MiBeacon format)
CGC1, CGG1, CGDK2, CGD1, CGP1W, CGH1, CGPR1
Xiaomi (Mi Scale format)
XMTZC01HM, XMTZC02HM, XMTZC04HM, XMTZC05HM, NUN4049CN
Sensors with custom ATC firmware (custom pvvx and/or atc1441 format)
LYWSD03MMC, MHO-C401, CGG1 and CGDK2
Govee
H5051, H5071, H5072, H5074, H5075, H5101, H5102, H5177, H5178, H5179, H5183
Oral-B
Toothbrush 7000 series
SensorPush
HT.w, HTP.xw
Kegtron
Kegtron KT-100, KT-200
Teltonika
Blue Puck RHT, Blue Puck T
Thermoplus
Smart Hygrometer, Lanyard Hygrometer, Mini Hygrometer
Brifit
T201
BlueMaestro
Tempo Disc THD and THDP
Ruuvitag
Ruuvitag sensors
Inkbird
iBBQ thermometer (1, 2, 4 and 6 probes versions), IBS-TH2
iNode
iNode Energy monitor, iNode care sensor 1 till 6, T, HT, PT, PHT
b-parasite
Plant sensor
Relsib
Relsib EClerk Eco
Beacon protocols
iBeacon protocol
altBeacon protocol
A list of all supported sensors with their description and image is available here.
Device Tracking
All devices with a static MAC address can be tracked with BLE monitor
This topic was created in addition to github issues as a place where you can more freely discuss the operation of the component, ask for support, leave feedback and share your experience.
If you are looking for support, please spend some time reading our Frequently Asked Questions , as it may already contain the answer to your question.
devices. You can now keep track the amount of beers from the tap in Home Assistant. I also splitted up the BLE parser in individual files, to make it easier in the future to add other sensors.
