I don’t think this device needs an encryption key, so you can leave it out.
Good to know, I’ll try without it. Thanks.
I had not seen that there was a post, I made a new request here
Could you help me ?
Thank you for everything
I am also interested in this. What’s your status on this? To avoid that I am starting work which you might already have done
We have a special page with instructions on how to collect passive BLE data. After you collect this, create a new issue on github with the data attached, and I will have a look.
Not that BLEmonitor cant connect to devices, only passive/active scanning.
Thanks for your answer, I already looked at this page but I can’t get the logs to send them to you.
I am on a Hassio image and therefore limited on the terminal.
The first method under “Getting BLE advertisements with the Home Assistant logger” works without any terminal. Also on Hassio
Hi, i have JTYJGD03MI Smoke detector. What do i do to integrate it in ha? I’ve followed all procedures described for other devices without success. I think the main problem is i can’t find the mi bind key but only the token.
Someone can help me?
thanks
Did you check the faq with instruction how to get the bindkey?
i used the modified version of mi home but i can’t find the pairings.txt file but only devices.txt where i can find only the token.
I tried the app for mac osx but i found only the token.
Any solution to find it?
Logger
: homeassistant.components.sensor
Source: components/sensor/__init__.py:608
Integration: Сенсор (documentation, issues)
First occurred: 22:50:47 (4 occurrences)
Last logged: 22:50:47
Sensor sensor.ble_heart_rate_f3187ff2133e has device class None, state class measurement and unit bpm thus indicating it has a numeric value; however, it has the non-numeric value: unknown (<class 'str'>); Please update your configuration if your entity is manually configured, otherwise report it to the custom integration author.
Sensor sensor.ble_steps_f3187ff2133e has device class None, state class total and unit steps thus indicating it has a numeric value; however, it has the non-numeric value: unknown (<class 'str'>); Please update your configuration if your entity is manually configured, otherwise report it to the custom integration author.
Sensor sensor.ble_heart_rate_f8bb08c875b3 has device class None, state class measurement and unit bpm thus indicating it has a numeric value; however, it has the non-numeric value: unknown (<class 'str'>); Please update your configuration if your entity is manually configured, otherwise report it to the custom integration author.
Sensor sensor.ble_steps_f8bb08c875b3 has device class None, state class total and unit steps thus indicating it has a numeric value; however, it has the non-numeric value: unknown (<class 'str'>); Please update your configuration if your entity is manually configured, otherwise report it to the custom integration author.
Hello , I have a problem with miband4 and miband 5 no info is displayed, active scanning is enabled according to the manual
An RSSI value of 0 is strange. Please enable debug logging for ble monitor and create an issue on github. The errors in the first message will be fixed in the next HA release, if I remember correct.
I have read and put what I need in the configuration.yaml but I don’t know where to look. I can’t find the file ``custom_components.ble_monitor```.
I must be very stupid
If you can’t find that folder, the question is did you install it?
Of course it has been installed, here is what I have in it:
And here is the configuration.yaml
And in ble:
That looks ok. Now check the HA logs in HA itself. It is in one of the setting/configuration menu’s.
Thank you for your patience, I wasn’t looking in the right place at all.
I have logs but I don’t know if it’s enough. So I have to open a problem to submit the logs to you, right?
Yes, that is the easiest.
