Path to access files stored in /share
So I’m using Node-Red in hassio and I have a bunch of icons I want to use to display on a dashboard. I stored them in “/share/node-red/icons” but now I can’t figure out what is the exact path I need to use to open them externally, i.e from a browser
If you want to use them externally put them in /config/www/node-red/icons/.
This can be accessed by [ip_address:port]/local/node-red/icons/
That works, but they are accessible on the homeassistant port 8123, not on the node-red port 1880
Yeah sorry I should have been clearer about that.
This really helped, thanks!
