Paulmann 501.34 (4 button wall switch) dimming with ZHA and Adaptive Lighting
Requirements:
  • Only works with ZHA
  • Adaptive Lighting custom component needs to be active
  • If you want to control multiple lights with one set of the buttons, you need to create a ZHA group (not a Homeassistant helper group), otherwise dimming will be very unreliable.
Features:
  • You can control dimming with different sliders. Just leave them as is or play around with the values to get a smooth dimming experience.
  • Long-pressing the Up-Buttons will turn on the light with minimum brightness if it was off.
  • When dimming down, it will stop at the minimal brightness and not turn off the lights completely.
  • Pressing the Up-Buttons while the light is already on will make Adaptive Lighting take over control and set it to the brightness that is specified there.
Disclaimer:
  • This is my first blueprint, so expect bugs and problems to happen!
  • If you have any recommendations or tipps, feel free to comment here.
blueprint:
  name: Paulmann 4 Button Wall Switch
  description: >-
    Create automations for the four-button Paulmann wall switch. This blueprint
    only supports ZHA, you also need to have Adaptive Lighting installed and running.
    If you dim up while the light is off, it will turn on at the minimum brightness
    you selected. If you dim it all the way down, it will stop dimming when it reaches
    the minimum brightness. Turning the light on while it is already on will restore
    control by Adaptive Lighting.
  domain: automation
  input:
    paulmann_switch:
      description: Select the Switch
      selector:
        device:
          filter:
            - integration: zha
              model: '501.34'
    light_left:
      description: >-
        Select the lights to be controlled via the buttons on the left
        side of the switch. If you want to control multiple lights, you must
        create a ZHA group.
      selector:
        entity:
          domain:
            - light
    light_right:
      description: >-
        Select the lights to be controlled via the buttons on the right
        create a ZHA group.
      selector:
        entity:
          domain:
            - light
    brightness_step_percent:
      name: Brightness Step Size
      description: >-
        How much the brightness of the light will change in each step during dimming (in %).
        Default: 5
      default: 5
      selector:
        number:
          min: 0
          max: 10
          step: 1
          mode: slider
    delay_ms:
      description: 'Delay after each brightness change during dimming (in ms, default: 200)'
      default: 200
      selector:
        number:
          min: 50
          max: 1000
          step: 50
          mode: slider
    transition_speed:
      description: >-
        Set this to the same value as Delay to get a smooth dimming effect (in ms,
        default: 200)
      default: 200
      selector:
        number:
          min: 0
          max: 1000
          step: 50
          mode: slider
    minimal_brightness:
      name: Minimal Brightness
      description: >-
        Dimming down stops at this value. Dimming up while the light is off
        will turn on the light at this value. The range is from 0 (off)
        to 255 (maximum brightness). Default: 15
      default: 15
      selector:
        number:
          min: 0
          max: 255
          step: 5
          mode: slider
    al_entity:
      name: Adaptive Lighting Entity
      description: Select your adaptive lighting entity here
      selector:
        entity:
          domain:
            - switch
          filter:
            - integration: adaptive_lighting
mode: restart
  - device_id: !input paulmann_switch
    domain: zha
    platform: device
    type: remote_button_short_press
    subtype: button_1
    domain: zha
    platform: device
    subtype: button_2
    domain: zha
    platform: device
    subtype: button_3
    domain: zha
    platform: device
    subtype: button_4
    domain: zha
    platform: device
    type: remote_button_long_press
    subtype: button_1
    domain: zha
    platform: device
    subtype: button_2
    domain: zha
    platform: device
    subtype: button_3
    domain: zha
    platform: device
    subtype: button_4
    domain: zha
    platform: device
    type: remote_button_long_release
    subtype: button_1
    domain: zha
    platform: device
    subtype: button_3
  - variables:
      helper_brightness_step_pos: !input brightness_step_percent
      helper_brightness_step_neg: '{{ helper_brightness_step_pos |int * -1 }}'
      helper_transition_speed_ms: !input transition_speed
      helper_transition_speed: '{{ helper_transition_speed_ms |int / 1000 }}'
      helper_delay_ms: !input delay_ms
  - choose:
      - conditions:
          - condition: trigger
            id:
              - btn1_press
        sequence:
          - service: adaptive_lighting.set_manual_control
              manual_control: false
              entity_id: !input al_entity
              lights: !input light_left
          - service: light.turn_on
              entity_id: !input light_left
      - conditions:
            id:
              - btn2_press
        sequence:
          - service: light.turn_off
      - conditions:
            id:
              - btn3_press
        sequence:
              lights: !input light_right
              entity_id: !input light_right
      - conditions:
            id:
              - btn4_press
        sequence:
      - conditions:
            id:
              - btn1_longpress
        sequence:
          - if:
              - condition: state
                state: 'off'
            then:
                  brightness: !input minimal_brightness
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 0
                  milliseconds: '{{ helper_delay_ms }}'
          - repeat:
              sequence:
                    brightness_step_pct: '{{ helper_brightness_step_pos }}'
                    transition: '{{ helper_transition_speed }}'
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
              while:
                - condition: numeric_state
                  attribute: brightness
                  below: 255
                  id:
                    - btn1_longpress
      - conditions:
            id:
              - btn2_longpress
        sequence:
          - repeat:
              sequence:
                    brightness_step_pct: '{{ helper_brightness_step_neg }}'
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
              while:
                  above: !input minimal_brightness
                  id:
                    - btn2_longpress
      - conditions:
            id:
              - btn3_longpress
        sequence:
          - if:
              - condition: state
                state: 'off'
            then:
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 0
          - repeat:
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
              while:
                  below: 255
                  id:
                    - btn3_longpress
      - conditions:
            id:
              - btn4_longpress
        sequence:
          - repeat:
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
              while:
                  id:
                    - btn4_longpress
Great and thanks for this blueprint.
Is there a way to use it without adaptive lighting?
Sure! Try this:
blueprint:
  description: >-
    only supports ZHA. If you dim up while the light is off, it will turn on at the minimum
    brightness you selected. If you dim it all the way down, it will stop dimming when it reaches
  domain: automation
  input:
    paulmann_switch:
      selector:
        device:
          filter:
            - integration: zha
              model: '501.34'
    light_left:
      description: >-
        create a ZHA group.
      selector:
        entity:
          domain:
            - light
    light_right:
      description: >-
        create a ZHA group.
      selector:
        entity:
          domain:
            - light
      description: >-
        Default: 5
      default: 5
      selector:
        number:
          min: 0
          max: 10
          step: 1
          mode: slider
    delay_ms:
      default: 200
      selector:
        number:
          min: 50
          max: 1000
          step: 50
          mode: slider
    transition_speed:
      description: >-
        default: 200)
      default: 200
      selector:
        number:
          min: 0
          max: 1000
          step: 50
          mode: slider
    minimal_brightness:
      description: >-
      default: 15
      selector:
        number:
          min: 0
          max: 255
          step: 5
          mode: slider
mode: restart
    domain: zha
    platform: device
    subtype: button_1
    domain: zha
    platform: device
    subtype: button_2
    domain: zha
    platform: device
    subtype: button_3
    domain: zha
    platform: device
    subtype: button_4
    domain: zha
    platform: device
    subtype: button_1
    domain: zha
    platform: device
    subtype: button_2
    domain: zha
    platform: device
    subtype: button_3
    domain: zha
    platform: device
    subtype: button_4
    domain: zha
    platform: device
    subtype: button_1
    domain: zha
    platform: device
    subtype: button_3
  - variables:
  - choose:
      - conditions:
            id:
              - btn1_press
        sequence:
      - conditions:
            id:
              - btn2_press
        sequence:
      - conditions:
            id:
              - btn3_press
        sequence:
      - conditions:
            id:
              - btn4_press
        sequence:
      - conditions:
            id:
              - btn1_longpress
        sequence:
          - if:
              - condition: state
                state: 'off'
            then:
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 0
          - repeat:
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
              while:
                  below: 255
                  id:
                    - btn1_longpress
      - conditions:
            id:
              - btn2_longpress
        sequence:
          - repeat:
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
              while:
                  id:
                    - btn2_longpress
      - conditions:
            id:
              - btn3_longpress
        sequence:
          - if:
              - condition: state
                state: 'off'
            then:
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 0
          - repeat:
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
              while:
                  below: 255
                  id:
                    - btn3_longpress
      - conditions:
            id:
              - btn4_longpress
        sequence:
          - repeat:
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
              while:
                  id:
                    - btn4_longpress
Thank you so much!
Great Job!
Hi all,
does anyone use the Paulmann switch with Z2M?
I am looking for a blueprint for Z2M…
Thx in advance…
Hello, since Home Assistant currently doesn’t fully support MQTT devices in blueprints, you can help yourself in this way.
You can get the topic for your Paulmann switch from the logs in Zigbee2MQTT Page in Homeassistant (zigbee2mqtt/[topic]/action).
With this topic, you can use the following blueprint :slight_smile:
blueprint:
  description: >-
    supports zigbee2mqtt. If you dim up while the light is off, it will turn on at the minimum
    the minimum brightness. You find the topic in the 'Zigbee2MQTT' tab in your sidebar.
  domain: automation
  input:
    mqtt_topic:
      description: >-
        The MQTT topic to be monitored (e.g., 'zigbee2mqtt/[topic]/action')
      selector:
        text:
    light_left:
      description: >-
        create a group.
      selector:
        entity:
          domain:
            - light
    light_right:
      description: >-
        create a group.
      selector:
        entity:
          domain:
            - light
      description: >-
        Default: 5
      default: 5
      selector:
        number:
          min: 0
          max: 10
          step: 1
          mode: slider
    delay_ms:
      default: 200
      selector:
        number:
          min: 50
          max: 1000
          step: 50
          mode: slider
    transition_speed:
      description: >-
        default: 200)
      default: 200
      selector:
        number:
          min: 0
          max: 1000
          step: 50
          mode: slider
    minimal_brightness:
      description: >-
      default: 15
      selector:
        number:
          min: 0
          max: 255
          step: 5
          mode: slider
mode: restart
  - platform: mqtt
    topic: !input mqtt_topic
    payload: 'on_1'
  - platform: mqtt
    payload: 'off_1'
  - platform: mqtt
    payload: 'on_2'
  - platform: mqtt
    payload: 'off_2'
  - platform: mqtt
    payload: 'brightness_move_up_1'
  - platform: mqtt
    payload: 'brightness_move_down_1'
  - platform: mqtt
    payload: 'brightness_move_up_2'
  - platform: mqtt
    payload: 'brightness_move_down_2'
  - platform: mqtt
    payload: 'brightness_stop_1'
  - platform: mqtt
    payload: 'brightness_stop_2'
  - variables:
      helper_brightness_step_neg: '{{ helper_brightness_step_pos | int * -1 }}'
      helper_transition_speed: '{{ helper_transition_speed_ms | int / 1000 }}'
  - choose:
      - conditions:
            id:
              - btn1_press
        sequence:
      - conditions:
            id:
              - btn2_press
        sequence:
      - conditions:
            id:
              - btn1_longpress
        sequence:
          - if:
              - condition: state
                state: 'off'
            then:
              - delay:
          - repeat:
              sequence:
                - delay:
              while:
                  below: 255
                  id:
                    - btn1_longpress
      - conditions:
            id:
              - btn2_longpress
        sequence:
          - repeat:
              sequence:
                - delay:
              while:
                  id:
                    - btn2_longpress
      - conditions:
            id:
              - btn3_press
        sequence:
      - conditions:
            id:
              - btn4_press
        sequence:
      - conditions:
            id:
              - btn3_longpress
        sequence:
          - if:
              - condition: state
                state: 'off'
            then:
              - delay:
          - repeat:
              sequence:
                - delay:
              while:
                  below: 255
                  id:
                    - btn3_longpress
      - conditions:
            id:
              - btn4_longpress
        sequence:
          - repeat:
              sequence:
                - delay:
              while:
                  id:
                    - btn4_longpress
Thanks for this blueprint, everyone!
I installed the last one from 1n9o in HA with Z2M. I paired it with a couple of lamp groups. Switching on and off works, but no luck with the dimming my wife wants :wink: even though the actions can be seen in the Z2M tab Exposes!
The lamps also dimm when actuated directly.
What gives? Could it be something I forgot when setting up the groups in Z2M? I can’t figure it out.
Thanks!
I think the original blueprint only works with single lamps, but not with light groups. If I have some time to spare, I’ll look into it and maybe update the blueprint.
