Paulmann 501.34 Wall Switch
I bought a Paulmann 4-Button Switch Wandschalter Smart Home Zigbee On/Off/Dimm Weiß to control my lights. I paired it with my Conbee2 Stick without any problems. This is the Zigbee Signature I got from the device:
“node_descriptor”: “NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4644, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)”,
“endpoints”: {
“1”: {
“profile_id”: 260,
“device_type”: “0x0001”,
“in_clusters”: [
“0x0000”,
“0x0001”,
“0x0003”,
“0x0b05”,
“0x1000”
“out_clusters”: [
“0x0003”,
“0x0004”,
“0x0005”,
“0x0006”,
“0x0008”,
“0x0019”,
“0x0300”,
“0x1000”
“2”: {
“profile_id”: 260,
“in_clusters”: [
“0x0000”,
“0x0001”,
“0x0003”,
“0x0b05”,
“0x1000”
“out_clusters”: [
“0x0003”,
“0x0004”,
“0x0005”,
“0x0006”,
“0x0008”,
“0x0019”,
“0x0300”,
“0x1000”
“manufacturer”: “Paulmann LichtGmbH”,
“model”: “501.34”,
“class”: “zigpy.device.Device”
Unfurtunately I didn’t find a blueprint for using this switch and I am not a real expert in Home Assistant - more or less a beginner (with IT background). Is it possible to use this switch in HA? Any ideas how to get it working in HA? I tried several things with other similar blueprints, but for example, I couldn’t dimm a light and the difference between the right and the left side of the switch is not working.
It would be great, if anyone could help me!
I got the same switch. Were you able to set it up?
I looked into it and it turns out you need a so called zigpy “quirk” to make it show up in automations. I opened a pull request in the zha device-handler repo
Finally the pull request has made it into HA with the current release v2022.9.4. You should be able to use it within automations.
Hello, how did you learn the Switch at Conbee2. it doesn’t work for me.
sorry for my english.Iam from germany
YES - now it’s working. I paired it once again with Conbee2 and I can control the lamps with the switches. Unfortunately the dimming is not working continuously - it dims up and down only to the next level. But it’s fine for me now.
I paired
Paulmann 501.34 Wall Switch (Wandschalter Smart Home Zigbee 3.0 On/Off/Dimm Weiß)
with
Home Assistant 2023.10.3
Supervisor 2023.10.0
Operating System 11.0
Frontend 20231005.0 - latest
and
ZHA
I cannot find any possibility to integrate the Paulmann 501.34 Wall Switch in any automation.
I only find 1 device
with 4 entities
Can you see the quirk being used under Zigbee info in the device settings?
@MattFromGer:
Please check
I hope I managed to include all necessary informations.
@MattFromGer :
@all:
is fixed by
Credits to: Profile - MattFromGer - Home Assistant Community & javicalle · GitHub
Hello, could someone please tell me how I can get these switches into pairing mode for Zigbee (Zigbee2MQTT) please? Thank you in advance
Don’t know if this is helping anyone but decided to share as this post popped when I tried to search for an answer to use Paulmann switch with HA (paulmann 501.37)
I’m controlling two Paulmann zigbee dimmers (Plug & Shine Controller Smart Home Zigbee 3.0 24V max. 75W Black) with following automations (four in total), could be done with one or less rows, but not coder so decided to stick what works.
device_ieee can be found fron the device info. Hope this helps someone, took me a few hours to get this working.
  • id: paulmann_valo1_on
    alias: Valo 1 päälle (Paulmann yläpainike)
    • trigger: event
      event_type: zha_event
      event_data:
      device_ieee:
      command: ‘on’
      endpoint_id: 1
      condition:
    • service: light.turn_on
      entity_id: light.paulmann_licht_gmbh_dimmable
  • id: paulmann_valo1_off
    alias: Valo 1 pois (Paulmann yläpainike)
    • trigger: event
      event_data:
      device_ieee:
      command: ‘off’
      endpoint_id: 1
      condition:
    • service: light.turn_off
  • id: paulmann_valo2_on
    alias: Valo 2 päälle (Paulmann alapainike)
    • trigger: event
      event_data:
      device_ieee:
      command: ‘on’
      endpoint_id: 2
      condition:
      entity_id: light.paulmann_licht_gmbh_dimmable_2
  • id: paulmann_valo2_off
    alias: Valo 2 pois (Paulmann alapainike)
    • trigger: event
      event_data:
      device_ieee:
      command: ‘off’
      endpoint_id: 2
      condition:
