Currently, there is no way to send service requests to OctoPrint via Home Assistant? IMHO, the most significant such feature would the ability to Pause/Resume the prints.
I would use this together with APCUPSD statuses. When grid is off for 2 minutes, pause the print. Once the grid is stable for more than 15 minutes, resume the print.
I need such a feature in order to be confident to start longer prints (24 hours +). I live in a place where grid failures are common and a 1400VA UPS does not seem to solve my issue with prints being cancelled…
This is a good idea, I have planned on adding this but was waiting on https://github.com/hroncok/octoclient to finish up his library so I wasn’t duplicating the work. I’ll look in to adding this and see how it goes.
It looks like that project’s been pretty much abandoned. No movement on this depo for more than a year… Looks like “Job operations” have all been achieved though:
Job operations
Yeah I noticed when I posted that. I’ll take a look and see if it is in a working state and use it if it is. If not I may fork it and get it working.
Multiple hosts would be great, but if all else fails, we can add this via Custom Components!
I’ve had to do this with ModBus integration and it’s easy as pie… Search for modbus1 on here and you should find the code and changes needed for the .py file, if you want to do this now! Waiting for my second printer to get here before I can test a variation of this for the OctoPrint component.
Looking through that thread, it’s pretty much the same for sending a pause/resume command. There are more examples later in the thread too. I’ll give this a shot.
