So I am trying to pass payload data from an array of light entities and cannot seem to figure out where I’m going wrong here.
What should happen is that I turn on “Maintenance Mode” and the flow grabs all of the light entities, puts them in an array and then then turns on each light in the array. The issue seems to be with how the payload is sent to the “Call Service” node.
[{"id":"2c08f48fa6f42b3a","type":"server-state-changed","z":"d0062682251ddce4","name":"Maintenance Mode","server":"58789d9e.7d1274","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"input_boolean.maintenance_mode","entityIdType":"exact","outputInitially":false,"stateType":"str","ifState":"on","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":6260,"wires":[["1f14eb2e7509b75f"],[]]},{"id":"0af558cd276d527f","type":"function","z":"d0062682251ddce4","name":"Filter Light Entities","func":"var allEntities = msg.payload;\n\n// Ensure the payload is an array\nif (!Array.isArray(allEntities)) {\n allEntities = [allEntities];\n}\n\n// Filter entities to only include light entities\nvar lightEntities = allEntities.filter(entity => entity.entity_id && entity.entity_id.startsWith('light.'));\n\n// Log the number of light entities found\nnode.log('Total light entities: ' + lightEntities.length);\n\n// Set the payload to the filtered light entities array\nmsg.payload = lightEntities;\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":6260,"wires":[["0dcf9e27b5214128"]]},{"id":"1f14eb2e7509b75f","type":"http request","z":"d0062682251ddce4","name":"Get All Entities","method":"GET","ret":"obj","paytoqs":"ignore","url":"http://192.168.0.5:8123/api/states","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"bearer","senderr":false,"headers":[{"keyType":"Authorization","keyValue":"","valueType":"other","valueValue":"Bearer eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiJjYzM0M2YyYTZmNGY0MDJlYWFhOGRiYTIyNjA3ZmQ3MyIsImlhdCI6MTcxODE1OTgzMiwiZXhwIjoyMDMzNTE5ODMyfQ.FigHP-gYQrDd58aS94Wgs61YSfpSiMNuT2aHv9BIxj8"}],"x":340,"y":6260,"wires":[["0af558cd276d527f"]]},{"id":"0dcf9e27b5214128","type":"function","z":"d0062682251ddce4","name":"Turn On All Light Entities","func":"var lightEntities = msg.payload;\n\n// Ensure the payload is an array\nif (!Array.isArray(lightEntities)) {\n node.error('Payload is not an array');\n return null;\n}\n\n// Log the number of light entities found\nnode.log('Total light entities: ' + lightEntities.length);\n\n// Create a new message for each light entity to turn it on\nvar turnOnMessages = lightEntities.map(function(entity) {\n return {\n payload: {\n domain: 'light',\n service: 'turn_on',\n data: {\n entity_id: entity.entity_id\n }\n }\n };\n});\n\n// Return all the turn on messages as an array\nreturn [turnOnMessages];","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":780,"y":6260,"wires":[["17434471df46284d"]]},{"id":"17434471df46284d","type":"split","z":"d0062682251ddce4","name":"Split Light Entities","splt":"\\n","spltType":"str","arraySplt":"1","arraySpltType":"len","stream":false,"addname":"","x":990,"y":6260,"wires":[["be037d8586c1855f"]]},{"id":"4f080f7802b782c4","type":"api-call-service","z":"d0062682251ddce4","name":"Call Service: Light Turn On","server":"edd49280cd758581","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","output_location":"","output_location_type":"none","x":1400,"y":6260,"wires":[[]]},{"id":"be037d8586c1855f","type":"change","z":"d0062682251ddce4","name":"Format Message","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"domain\": \"light\", \"service\": \"turn_on\", \"data\": {\"entity_id\": msg.payload.data.entity_id}}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1190,"y":6260,"wires":[["4f080f7802b782c4"]]},{"id":"58789d9e.7d1274","type":"server","name":"Home Assistant","addon":true},{"id":"edd49280cd758581","type":"server","name":"Home Assistant","addon":true}]`Preformatted text`
