Payload is not supported (e.g. open, closed, opening, closing, stopped): stop
dear all,
I’ve a lot of message like the followin in my log:
2021-05-07 21:45:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not supported (e.g. open, closed, opening, closing, stopped): stop
2021-05-07 21:45:05 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not supported (e.g. open, closed, opening, closing, stopped): stop
2021-05-07 21:45:08 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not supported (e.g. open, closed, opening, closing, stopped): stop
following a sample of my cover config:
  - platform: mqtt
    unique_id: tapparella_camera
    state_topic: "shellies/shellyswitch25-F40ADC/roller/0"
    command_topic: "shellies/shellyswitch25-F40ADC/roller/0/command"
    position_topic: "shellies/shellyswitch25-F40ADC/roller/0/pos"
    set_position_topic: "shellies/shellyswitch25-F40ADC/roller/0/command/pos"
    availability_topic: "shellies/shellyswitch25-F40ADC/online"
    payload_available: "true"
    payload_not_available: "false"
    qos: 1
    retain: false
    payload_open: "open"
    payload_close: "close"
    payload_stop: "stop"
    position_open: 100
    position_closed: 0
    optimistic: false
anyone can give me ant suggestion?
thanks in advance
regards
Stefano
You have defined the payloads for the command topic but not the state topic. See this option and the ones below it: https://www.home-assistant.io/integrations/cover.mqtt/#state_closed
Hi
same warning here.
Logger: homeassistant.components.mqtt.cover
Source: components/mqtt/cover.py:328
Integration: MQTT (documentation, issues)
First occurred: 9:49:41 (1 occurrences)
Last logged: 9:49:41
Payload is not supported (e.g. open, closed, opening, closing, stopped): {“Time”:"2021-05-…
My configuration is :
cover:
platform: mqtt
device_class: shutter
availability_topic: “tele/Lucernario/LWT”
payload_available: “Online”
payload_not_available: “Offline”
command_topic: “cmnd/Lucernario/Backlog”
payload_open: “ShutterOpen1”
payload_close: “ShutterClose1”
payload_stop: “ShutterStop1”
state_open: “open”
state_opening: “opening”
state_closed: “closed”
state_closing: “closing”
state_stopped: “stepped”
set_position_topic: ‘cmnd/Lucernario/ShutterPosition1’
position_topic: “stat/Lucernario/RESULT”
position_open: 100
position_closed: 0
position_template: >
{% if (‘Shutter1’ in value_json) and (‘Position’ in value_json.Shutter1) %}
{{ value_json.Shutter1.Position }}
{% else %}
{% if is_state(‘cover.tappatest’, ‘unknown’) %}
50
{% else %}
{{ state_attr(‘cover.tappatest’,‘current_position’) }}
{% endif %}
{% endif %}
retain: false
optimistic: false
qos: 1
Anyway all seems work fine but I have annoying to see that warning on log.
Any ideas for fix…Thanks in advance.
Did you misspell “stopped”?
Thanks for your reply…I need some glasses…:slight_smile: I have corrected “stopped”
unfortunately the warning come again.
Can you copy and paste the full error text?
My warnings on cover Integration
Source: components/mqtt/cover.py:368
First occurred: 10:21:26 (4 occurrences)
Last logged: 10:21:27
Payload ‘None’ is not numeric
First occurred: 10:21:26 (2 occurrences)
Payload is not supported (e.g. open, closed, opening, closing, stopped): {“Time”:“2021-05-08T10:21:27”,“Uptime”:“5T23:54:08”,“UptimeSec”:518048,“Heap”:25,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:19,“POWER1”:“ON”,“POWER2”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“Enlafra”,“BSSId”:“38:10:D5:BB:46:7E”,“Channel”:11,“RSSI”:50,“Signal”:-75,“LinkCount”:14,“Downtime”:“0T00:00:35”}}
Payload is not supported (e.g. open, closed, opening, closing, stopped): {“Time”:“2021-05-08T10:21:27”,“Uptime”:“5T23:54:08”,“UptimeSec”:518048,“Heap”:25,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:22,“MqttCount”:19,“POWER1”:“OFF”,“POWER2”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“Enlafra”,“BSSId”:“38:10:D5:BB:46:7E”,“Channel”:11,“RSSI”:50,“Signal”:-75,“LinkCount”:14,“Downtime”:“0T00:00:35”}}
It looks like the topic you are using for state messages is also receiving this message from your device:
If your cover is working as expected (start/stop/open/close/…ect) you have three choices,
  1. ignore the warning.
  2. develop templates to ignore that particular message.
  3. pick a better state topic.
Hi, thanks for suggestion, but probably I’m loosing somethings, I’ve changed my config, here the new one:
  - platform: mqtt
    unique_id: tapparella_cucina
    state_topic: "shellies/shellyswitch25-C4B6A1/roller/0"
    command_topic: "shellies/shellyswitch25-C4B6A1/roller/0/command"
    position_topic: "shellies/shellyswitch25-C4B6A1/roller/0/pos"
    set_position_topic: "shellies/shellyswitch25-C4B6A1/roller/0/command/pos"
    availability_topic: "shellies/shellyswitch25-C4B6A1/online"
    state_open: "open"
    state_opening: "opening"
    state_closed: "closed"
    state_closing: "closing"
    state_stopped: "stopped"
    qos: 1
    retain: false
    position_open: 100
    position_closed: 0
    optimistic: false
but the warning in the log file still be …
Any suggestion? … MQTT deice are Shelly 2.5.
Thanks again, regards
Stefano
Yeh I can try some different templates or ignore the warning.
Fortunately the cover works great, this message isn’t a problem.
thanks again
Hi, had the same problem, since updated to latest home assistant version. You’re almost there, try these state commands:
state_open: "open"
state_closed: "close"
state_stopped: "stop"
pay attention to the difference “stopped, closed” and “stop, close”. My warnings are now gone.
Thanks for your suggestion, in the meanwhile a did a simplification of the MQTT definition, now it’s like:
  - platform: mqtt
    qos: 1
    retain: false
    position_open: 100
    position_closed: 0
after doing this, warning in log disappear.
thanks to all
Regards
Stefano
