PayloadTooLargeError: request entity too large
at readStream (/opt/node_modules/body-parser/node_modules/raw-body/index.js:163:17)
at getRawBody (/opt/node_modules/body-parser/node_modules/raw-body/index.js:116:12)
at read (/opt/node_modules/body-parser/lib/read.js:79:3)
at jsonParser (/opt/node_modules/body-parser/lib/types/json.js:138:5)
at Layer.handle [as handle_request] (/opt/node_modules/express/lib/router/layer.js:95:5)
at trim_prefix (/opt/node_modules/express/lib/router/index.js:328:13)
at /opt/node_modules/express/lib/router/index.js:286:9
at Function.process_params (/opt/node_modules/express/lib/router/index.js:346:12)
at next (/opt/node_modules/express/lib/router/index.js:280:10)
at cors (/opt/node_modules/cors/lib/index.js:188:7)
at /opt/node_modules/cors/lib/index.js:224:17
at originCallback (/opt/node_modules/cors/lib/index.js:214:15)
at /opt/node_modules/cors/lib/index.js:219:13
at optionsCallback (/opt/node_modules/cors/lib/index.js:199:9)
at corsMiddleware (/opt/node_modules/cors/lib/index.js:204:7)
at expressInit (/opt/node_modules/express/lib/middleware/init.js:40:5)
Fortunately for me, Google Translate knows that Развертывание не удалось is Deployment Failed in English.
Nothing then to do with the Current state node - I assume that you are attempting a deployment and the size of the NR editor flow update passed to the Node-RED runtime API webhook exceeds the standard permitted length. You must have a very large flow?
There is a apiMaxLength parameter in Node-RED that will generate this message if exceeded. The default is, I believe, 5Mb.
You could, at your own risk, try changing the [Node-RED] settings.js file. The relevant bit [in this file] appears to be:
// The maximum size of HTTP request that will be accepted by the runtime api.
// Default: 5mb
//apiMaxLength: '5mb',
It looks like the solution is to uncomment the `apiMaxLength: ‘5mb’, and then increase this to 10mb.
For myself, I like to leave settings files well alone (unless I really do know what I am doing) and I would personally try reducing the size of the flow until the problem went away of its own accord.
Home Assistant Add-on: Samba share
Installation
Follow these steps to get the add-on installed on your system:
Navigate in your Home Assistant frontend to Settings -> Add-ons -> Add-on store.
Find the "Samba share" add-on and click it.
Click on the "INSTALL" button.
How to use
In the configuration section, set a username and password. You can specify any username and password; these are not related in any way to the login credentials you use to log in to Home Assistant or to log in to the computer with which you will use Samba share.
Review the enabled shares. Disable any you do not plan to use. Shares can be re-enabled later if needed.
Connection
If you are on Windows you use \\<IP_ADDRESS>\, if you are on MacOS you use smb://<IP_ADDRESS> to connect to the shares.
This addon exposes the following directories over smb (samba):
Directory Description
addons This is for your local add-ons.
addon_configs This is for the configuration files of your add-ons.
backup This is for your backups.
config This is for your Home Assistant configuration.
media This is for local media files.
share This is for your data that is shared between add-ons and Home Assistant.
ssl This is for your SSL certificates.
Install it
Configure it
Use it - on a PC \\<IP_ADDRESS>
