Hello
I’m struggling with stairs led strips
I have wemos d1 mini + pca9685
On tasmota is working.
Onesphome latest version it seems that is totally killing CPU, OTA is impossible, logs dropping connection, device is resetting when script is initiated
Bellow you will find my code
substitutions:
device: schody
room: Schody
ip: 192.168.19.73
transition_lenght: 400ms
stairs_awake_lenght: 20s
light_brightness: 51%
esphome:
friendly_name: ${room}
platform: ESP8266
board: d1_mini
<<: !include common/common.yaml
status_led:
pin: GPIO2
i2c:
sda: D2
scl: D1
scan: true
frequency: 10000
pca9685:
- id: pca9685_hub1
frequency: 500
address : 0x40
output:
- platform: pca9685
pca9685_id: 'pca9685_hub1'
channel: 0
- platform: pca9685
channel: 1
- platform: pca9685
channel: 2
- platform: pca9685
channel: 3
- platform: pca9685
channel: 4
- platform: pca9685
channel: 5
- platform: pca9685
channel: 6
- platform: pca9685
channel: 7
- platform: pca9685
channel: 8
- platform: pca9685
channel: 9
- platform: pca9685
channel: 10
- platform: pca9685
channel: 11
- platform: pca9685
channel: 12
- platform: pca9685
channel: 13
- platform: pca9685
channel: 14
- platform: pca9685
channel: 15
light:
- platform: monochromatic
output: pwm01
flash_transition_length: ${transition_lenght}
output: pwm02
output: pwm03
output: pwm04
output: pwm05
output: pwm06
output: pwm07
output: pwm08
output: pwm09
output: pwm10
output: pwm11
output: pwm12
output: pwm13
output: pwm14
output: pwm15
output: pwm16
switch:
- platform: restart
binary_sensor:
- platform: gpio
pin:
number: D6
mode:
input: true
pullup: true
inverted: true
name: "${room} czujnik dolny"
- platform: gpio
pin:
number: D7
mode:
input: true
pullup: true
inverted: true
name: "${room} czujnik górny"
button:
name: "Schody dół góra"
on_press:
then:
- script.execute: schodydowupnon
- delay: ${stairs_awake_lenght}
- script.execute: schodydowupnoff
name: "Schody góra dół"
on_press:
then:
- script.execute: schodyupdownon
- delay: ${transition_lenght}
- script.execute: schodyupdownoff
script:
- id: schodyupdownon
then:
- light.turn_on:
brightness: ${light_brightness}
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- id: schodyupdownoff
then:
- light.turn_on:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- id: schodydowupnon
then:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- id: schodydowupnoff
then:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
