Looking for a way to pull the Battery information from a Pentair Home Battery Backup System
Thanks!
Thanks!
does anyone have any idea how i’d go about potentially working on a way to integrate this unit?
I just started working on an integration for my salt level sensor that is through Pentair Home. Did you ever make any progress on this?
Unfortunately it’s out of my ability. Only thing i’ve figured out is the smart battery talks over some radio frequency to a gateway device that sends it to the cloud in aws. Outside of that I don’t think there are any available APIs to access it. As well, the only way I think you could intercept it locally would be through listening perhaps on the radio frequency between the battery and the gateway.
I could potentially help here, but I don’t have the device you do, so you’ll need to add the following and enable debugging to see if the data comes back similar to my salt level sensor.
