The current Pentair integration does not support setting speed or flow rate for variable speed pumps.
As home assistant user, I want to be able to adjust the speed or flow rate for a variable speed pump by using a slider in LoveLace so I can better control my pool.
Note: Pentair exposes “Switches” for each speed defined in Screenlogic. The App allows setting the speed or flow rate (depending on the pump type) per switch. For the integration, it would mean that there has to be one slider for each switch.
