Pentair Pump Controller
I figured someone might find this useful so I am putting it here. I have a Pentair PID30 pump controller and wanted to get it into HA. I initially was just going to use it’s programmable IO to get some state info and maybe be able to remotely disable it. I saw it had what looked like an RS485 connection and ended up finding this:
I had a set of these on hand:
and threw together an interface and was able to successfully communicate with the controller! I don’t have all the control I want, but I have basically everything. (One of the big things I wanted was the ability to change the amperage limit, I was able to get it down to about 7 amps and still get up to pressure. This makes it easier to run on generator power as the pump does not load the generator up so badly)
Here is my Current ESPHome YAML:
esphome:
  friendly_name: PumpController
esp8266:
  board: esp01_1m
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "Something"
ota:
  password: "Something"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Pumpcontroller Fallback Hotspot"
captive_portal:
web_server:
  port: 80
  auth:
    username: !secret esphome_web_username
    password: !secret esphome_web_password
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 19200
modbus:
  flow_control_pin: GPIO4
modbus_controller:
  - id: pentair1
    address: 0x1
    modbus_id: modbus1
    update_interval: 5s
  - id: pentair2
    address: 0x2
    modbus_id: modbus1
    update_interval: 1s
select:
  - platform: modbus_controller
    modbus_controller_id: pentair2
    name: "Set Pressure"
    icon: mdi:waves-arrow-up
    address: 218
    value_type: S_WORD
    optionsmap:
      "60": 414
      "65": 448
      "68": 469
      "70": 483
    modbus_controller_id: pentair1
    icon: mdi:current-ac
    address: 5200
    value_type: S_WORD
    optionsmap:
      "10.1": 16673
      "9.1": 16657
      "8.1": 16641
      "7.1": 16611
      "6.1": 16579
    name: "Pressure Setpoint"
    address: 218
    unit_of_measurement: "PSI"
    icon: mdi:water
    register_type: holding
    value_type: U_WORD
    accuracy_decimals: 1
    filters:
      - multiply: 0.145038
    name: "Current Pressure"
    address: 221
    icon: mdi:water-circle
    value_type: U_WORD
    filters:
    icon: mdi:water-check
    address: 33
    value_type: U_WORD
binary_sensor:
    icon: mdi:sleep
    address: 216
Here is my Original ESPHome YAML I used:
esphome:
  friendly_name: WaterMonitor
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
  baud_rate: 0
api:
  encryption:
    key: ""
ota:
  password: ""
wifi:
  ap:
    ssid: "Watermonitor Fallback Hotspot"
    password: ""
captive_portal:
web_server:
  port: 80
  auth:
uart:
  tx_pin: 1
  rx_pin: 3
  baud_rate: 19200
modbus:
  flow_control_pin: 22
modbus_controller:
  - id: pentair1
    address: 0x1
    modbus_id: modbus1
    update_interval: 1s
  - id: pentair2
    address: 0x2
    modbus_id: modbus1
    update_interval: 1s
select:
    address: 218
    value_type: S_WORD
    optionsmap:
      "60": 414
      "65": 448
      "68": 469
      "70": 483
    address: 5200
    value_type: S_WORD
    optionsmap:
      "10.1": 16673
      "9.1": 16657
      "8.1": 16641
      "7.1": 16611
      "6.1": 16579
    address: 218
    value_type: U_WORD
    filters:
    address: 221
    value_type: U_WORD
    filters:
    address: 33
    value_type: U_WORD
binary_sensor:
    address: 216
    #bitmask: 0x80 #(bit 8)
Thank you so much for this.
I have a PID020 and I’d like to be able to reset it from homeassistant when it gets into an error after a powerfailure. Despite the fact that I have a generator, it often ends up stopped with an overcurrent or voltage error and I have to manually clear the error. Were you able to find the modbus mapping that would do a reset action?
I have asked my dealer to see if the app even has that function and no answer so far.
Since the app use a modbus module connected to the same port, we should be able to do whatever the app is doing.
I have not yet, though I have been considering trying again. (Last few times the generator came on line the controller came up in an error state, but I did not have time to troubleshoot). I am hoping the app can do it, as that would be really cool. As an alternative you can try mapping one of the digital inputs to “Run Enabled” and see if that clears the fault:
The last alternative would to solder a wire to the clear / run buttons and use a small relay to “press” the buttons with the ESP. I already am stealing 5V from the control panel to run my ESP, so it would not be a lot more to grab those two buttons for me. I spent a couple hours trying to find a register to switch between run and stop, but ran out of time unfortunately.
I’ve been working on the same problem for my PID10, and just wanted to bring your attention to some of the progress I’ve made on the read-only side of things. I haven’t made any progress on issuing commands.
Esphome config
Crowdsourced docs repo
Thanks for this I have a PID30 as well and am trying to figure out my runtime with a battery backup setup. I just wanted to monitor power usage and the idea of controlling amps is awesome. Has this been working well for you over the long haul (your post is a couple years old)?
Thanks again for this contribution!
Sweet! I yoinked your YAML and merged it with my value setting ones. I made an issue in your github about the power tracking too.
It has been working great for me. The powerhead on my generator can produce 14.5 kW continuous, but I have not fitted the supercharger to the engine yet, so it can only produce something like 9, so being able to restrain the pump helps it not brown out when the AC is running. I have a high current relay that cuts power to the controller immediately when power comes up after an outage and keeps it off for 300 seconds. This helps protect the controller, and allows voltage to stabilize first. I also will be hooking that ESPHome device up to pressure sensors on each filter housing so I can get an idea of which filter is restricted and how restricted. (I run a pair of particulate filters and a pair of activated charcoal filters, the second one is a block type and only feeds the water softener.)
