Pentair screen logic integration not working (Intellicenter i10)
So it’s not finding it automatically, when I put in the IP address, it can’t connect. It’s defaulting to port 80, which doesn’t pickup on the wifi device. (Engenius, came with the i10, basically acts like a wifi-access point)
I can connect locally from the Pentair Home app which is connecting to that IP. Must be using a different port? Not sure, I can setup a packet sniffer this weekend, but in the mean time anyone have any suggestions?
Used a packet sniffer to find the port, 6680. Now getting connection dropped? See here:
Logger: aiohttp.server
Source: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:421
First occurred: 7:53:08 PM (3 occurrences)
Last logged: 8:00:25 PM
Error handling request
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py”, line 452, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py”, line 543, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py”, line 114, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 91, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 100, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 25, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 79, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 235, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/headers.py”, line 31, in headers_middleware
response = await handler(request)
File “/usr/src/homeassistant/homeassistant/helpers/http.py”, line 68, in handle
result = await handler(request, **request.match_info)
File “/usr/src/homeassistant/homeassistant/components/http/decorators.py”, line 72, in with_admin
return await func(self, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 197, in post
return await super().post(request, flow_id)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 111, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 359, in async_configure
result = await self._async_configure(flow_id, user_input)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 405, in _async_configure
result = await self._async_handle_step(
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 502, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File “/usr/src/homeassistant/homeassistant/components/screenlogic/config_flow.py”, line 154, in async_step_gateway_entry
mac = format_mac(await login.async_get_mac_address(ip_address, port))
File “/usr/local/lib/python3.12/site-packages/screenlogicpy/requests/login.py”, line 32, in async_get_mac_address
mac = await async_gateway_connect(transport, protocol, max_retries)
File “/usr/local/lib/python3.12/site-packages/screenlogicpy/requests/login.py”, line 77, in async_gateway_connect
raise ScreenLogicConnectionError(“Host unexpectedly disconnected.”)
screenlogicpy.const.common.ScreenLogicConnectionError: Host unexpectedly disconnected.
