All:
Finally got my Pentair ScreenLogic pool/spa equipment all wired with HA now. I created everything you need in Docker and it’s easy to setup - just two things to setup.
Here’s a walk through on the process:
Docker containers:
https://hub.docker.com/repository/docker/cbschuld/pentair-screenlogic
and if you need MQTT you can use
https://hub.docker.com/_/eclipse-mosquitto
Background:
I was following Brian Woodworth’s work on getting Pentair working with HASSIO and it’s great but I do not use HASSIO so I inquired about decoupling it. I did; now you can essentially use a slightly modified version of his work without HASSIO.
