PEQ Door/Window sensor not reporting battery
Pretty new here from SmartThings. I have a few older PEQ Door/Window Sensors (Zigbee) that paired up just fine but do not show the battery status. They show open/close and temp just fine but show Unknown for battery.
I have this GoControl CECOMINOD016164 HUSBZB-1 USB Hub plugged into a NUC. The sensor reports as a Centralite 3300 if that helps.
Can someone point me in the right direction :slight_smile:
Thanks,
Scott
Did you ever get these working? I have the same issue with these, they report battery percentage in Smartthings but not HA.
