The generalized version of what I’m trying to do is: Take a set of entities (an array input in a blueprint) and then do a set of actions for each of them. In my case, I need this done in a serial fashion.
More specifically, I’m creating a “winterize” routine for my sprinkler system. I have a rachio smart sprinkler system and each zone shows up as a switch in Home Assistant. In the fall, I’ll be hooking up an air compressor to the water line. I need each zone to get turned on for about 60 seconds, then a delay for a couple minutes so the compressor can catch up. Right now, I just copy/pasted the actions for all the relevant zones. But a blueprint would just be more fun.
My attempts to do this in a blueprint with some templating have failed. Here’s some non functional code to better illustrate my goal.
blueprint:
description: Tests looping through entities.
domain: automation
source_url: "..."
input:
entities:
name: Entities To Process
description: The collection of entities to loop through.
default: []
selector:
entity:
filter:
domain: switch
multiple: true
variables:
entities: !input entities
mode: restart
{% for entityToProcess in entities %}
- service: switch.turn_on
data: {}
entity_id: {{ entityToProcess }}
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- service: switch.turn_off
data: {}
- delay:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
{% endfor %}
Eventually, the delay amounts would become inputs too so that I can tweak the process.
