Let me explain what I need to do:
From several physical push buttons connected to a NodeMcu I want to control several led’s (Milight) and blinds (Shelly).
The idea for the same button is:
-1st When I press the button, the milight light turns off and when I press it again it turns on.
-2nd When I press the button for more than 2 seconds, it works as a dimmer in the Milight.
In other projects I have programmed the NodeMcu independently, i.e. the pushbuttons act on the arduino’s own outputs and not on external entities.
I understand that I have to do it through MQTT but I would say that the bridges I have (https://www.diodhuset.com/wifi-bridge-for-mi-light) do not allow to receive MQTT, besides if I configure MQTT in Shelly I would lose the onCloud service.
Could I perform these button actions directly in Hassio, without having to call MQTT from the nodemcu?
Thanks for your recomendations! Sure I prefer to do it directly through the nodemcu .
I tried to do it with the command -Homeassistant.service: … but it doesn’t work for me, I mean it doesn’t change the status.
Let me put the code here with some comments
captive_portal:
logger:
api:
ota:
# ********** Pulsadores ********** #
binary_sensor:
- platform: gpio
pin:
number: D4
inverted: true
mode: INPUT_PULLUP
on_click:
then:
- homeassistant.service:
service: switch.toggle
entity_id: switch.light.led_sup_dorm_1 # HA entity
on_double_click:
then:
entity_id: switch.cover.shellyswitch25_dorm1 # Here I'd like to start moving up the curtain and once double click it again stop the movement. How can I define moving up or moving it down? becouse I'd use it to go down on another button
on_press: # Here I don't know how can I put it with the entity "light.led_sup_dorm_1" :( Below I have a previous code that I used to config an arduino mosfet directly in another nodemcu basically the idea is dimmering the light
# ********** LED Terraza *********** #
light:
- platform: monochromatic
output: light_0_out
output:
- platform: esp8266_pwm
pin: D0
# *********** LED Terraza Dimmer *********** #
- platform: gpio
pin: D6
on_click:
then:
- if:
condition:
light.is_off: light_0
then:
light.turn_on:
brightness: 1.0
else:
light.turn_off: light_0
on_press:
then:
- if:
condition:
then:
- delay: 0.5s
- while:
condition:
binary_sensor.is_on: light_0_touch
then:
- light.dim_relative:
relative_brightness: 5%
transition_length: 0.1s
- delay: 0.1s
else:
- delay: 0.5s
- while:
condition:
and:
- binary_sensor.is_on: light_0_touch
- light.is_on: light_0
then:
relative_brightness: -5%
- delay: 0.1s
ESPHome devices can make service calls to any Home Assistant service. This functionality is not enabled by default for newly configured device, but can be turned on the options flow on a per device basis.
Ok at the end I found another solution becaouse I couldn’t find the solution to do it directly in the Nodemcu.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "your_ssid"
password: "your_password"
manual_ip:
static_ip: 192.168.1.99
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Cabecera_Fallback_Hotspot"
password: "password"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
text_sensor:
name: Scene Button 1
lambda: |-
return {"Released"};
name: Scene Button 2
lambda: |-
name: Scene Button 3
lambda: |-
name: Scene Button 4
lambda: |-
### Botón 1 ###
binary_sensor:
- platform: gpio
pin:
number: D4
mode: INPUT_PULLUP
inverted: true
name: "Scene Button 1"
internal: true
filters:
delayed_on_off: 50 ms
on_multi_click:
- timing:
- ON for at least 1s
- OFF for at least 1s
then:
- text_sensor.template.publish:
state: "Hold"
- delay: 2 s
state: "Released"
- timing:
- ON for at most 0.5s
then:
state: "Clicked"
- delay: 2 s
state: "Released"
- timing:
- OFF for at most 0.5s
then:
state: "Double Clicked"
- delay: 2 s
state: "Released"
- timing:
then:
state: "Tripple Clicked"
- delay: 2 s
state: "Released"
- timing:
then:
state: "Fourth Clicked"
- delay: 2 s
state: "Released"
### Botón 2 ###
- platform: gpio
pin:
number: D2
mode: INPUT_PULLUP
inverted: true
name: "Scene Button 2"
internal: true
filters:
on_multi_click:
- timing:
then:
state: "Hold"
- delay: 2 s
state: "Released"
- timing:
then:
state: "Clicked"
- delay: 2 s
state: "Released"
- timing:
then:
- delay: 2 s
state: "Released"
- timing:
then:
- delay: 2 s
state: "Released"
- timing:
then:
- delay: 2 s
state: "Released"
### Botón 3 ###
- platform: gpio
pin:
number: D3
mode: INPUT_PULLUP
inverted: true
name: "Scene Button 3"
internal: true
filters:
on_multi_click:
- timing:
then:
state: "Hold"
- delay: 2 s
state: "Released"
- timing:
then:
state: "Clicked"
- delay: 2 s
state: "Released"
- timing:
then:
- delay: 2 s
state: "Released"
- timing:
then:
- delay: 2 s
state: "Released"
- timing:
then:
- delay: 2 s
state: "Released"
### Botón 4 ###
- platform: gpio
pin:
number: D1
mode: INPUT_PULLUP
inverted: true
name: "Scene Button 4"
internal: true
filters:
on_multi_click:
- timing:
then:
state: "Hold"
- delay: 2 s
state: "Released"
- timing:
then:
state: "Clicked"
- delay: 2 s
state: "Released"
- timing:
then:
- delay: 2 s
state: "Released"
- timing:
then:
- delay: 2 s
state: "Released"
- timing:
then:
- delay: 2 s
state: "Released"
So once I charged the code in the Node I can interact with Hassio throught an automatizations in this way:
I hope It can be usefull for someone (extracted from youtuber [kian.smarthome] )
Problem cames when you want to use the same state to alternate different actions ( for example: You want to use doble click to open the blind and the same double click to stop the blind. It seems it’s not possible because once you perform the “action” after 2 s of delay the state return to “Released” .
About the dimmer light I tried to do it trought an automation but it doesn’t work well (there is a big delay
since when I push the button to start dimming…
alias: Test Dimmer con Hold
- platform: state
entity_id: sensor.scene_button_1
to: "hold"
- repeat:
sequence:
- service: light.turn_on
data_template:
entity_id: light.led_cocina
brightness: "{{ (repeat.index / 10 * 255) | int }}"
- delay: "00:00:00.5"
until:
- condition: state
state: "released"
I’ve noticed that if I create automations in Hassio it takes at least 1,5 seconds to repond…
I’m trying to do it directly in the initial code of the board but it doesn’t work for me.
I’ve asked for it to ChatGpt and Bard but the only that I get from both are errors…
To do some tests, I just need a code to toogle the entity: “light.led_cocina_x3” when I press the button is conected to the pin D4
