Performance issues on RPI3
I have some performance issues with HA. I have added more and more stuf and now I am using some Node Red. Installed as a hass.io add-on. I get a lot of the “Timer got out of sync. Resetting” errors and I think it is just overloaded. However the CPU is not very high, the memory is about 50%.
I have considered using a Synology DS918+ instead. Maybe running only Node Red here or maybe HA as well. I know a lot are using Intel NUCS to. Is this still supported with docker. I noticed the link was removed. Or should I go with a Tinker board?
Or maybe there is something else that is not configured the way it should be causing my errors.
