Performance questions /issues
Hi all,
I’ve been using my Raspberry Pi 3B for quite some time and have recently just updated to the latest version of Home Assistant, after nearly 2 years of not having done so. I bought a new micro SD card and redid my whole setup from scratch (minus the old hass configuration yaml files, obviously).
My question to you guys is about performance. I sometimes feel as if my Home Assistant is a bit “slow” to react. A major performance issue I’ve been running into, is it not reflecting the real state of IKEA Tradfri lights: they appear to be turned on in hass, while they’re in fact turned off. If I click on a light in hass to turn it on, it will physically turn on, yet will remain displayed as turned off in hass (until I reload the Tradfri integration).
So my question here is:
  • What hardware do you guys run your hass on?
  • Has anyone experienced any similar issued?
Note that on the same raspberry pi, I run Home Assistant, ZWave JS UI, pi-hole, and Portainer, all of them running as docker compose containers.
Thanks!
Get a cheap second hand NUC or NUC-like and put HA on that, I have my instance in a Virtual Box headless virtual machine setup on my NUC5i7RYH and I have a passive cooled case for it from Akasa to keep it silent.
Everything is near instant for me and the only issue I have atm which I will be sorting once I have the funds is the cloud reliant air purifier since the app for it is constantly failing for me now (which breaks the intergration link).
Thanks for the tip! I actually have a few Raspberry Pi 5 laying around, and when testing those, it works flawlessly. I just want to extend the lifespan of my Raspberry Pi 3B as long as I can.
Yea if you have 5’s use one of them instead and invest in a SSD hat for it so you are not reliant on the microSD.
I have a Pi3 that is sitting in a box since I don’t know what I want to do with with at the moment (was using it at one point as a headless system I could remote into when I needed to check network settings at the parents place and not distrub them from using the PC they have at the time when they are on it).
Yeah pi3 is getting a bit old for that.
Also Portainer is no longer an approved addon.
