I am using puppeteer ( puppeteer/troubleshooting.md at e4c48d3b8c2a812752094ed8163e4f2f32c4b6cb · puppeteer/puppeteer · GitHub ) that recommends not using user root
(--no-sandbox
). For that reason, I created a new user (pptruser
Everything seems to be working fine, except the part I need to persist a session file…
[Error: EACCES: permission denied, open '/data/session.json'] {
errno: -13,
code: 'EACCES',
syscall: 'open',
path: '/data/session.json'
I saw this post ( Addon unable to reach /data/options.json. Permission denied. · Issue #2158 · home-assistant/supervisor · GitHub ) that says all JSON files are stored with 0600 and recommends using the API but I think (or at least I don’t know) I can’t use API to persist something in /data
folder.
I also saw this post ( Addon unable to reach /data/options.json. Permission denied. · Issue #2158 · home-assistant/supervisor · GitHub ) that says about configuring ownership and permissions but still no success because the file is created in runtime.
I also saw some discussions about /config
folder, but I can’t find it anymore. Maybe because I am stuck for the last 3 days.
So my questions are:
- First thing, is it correct to store persistent data to
/data
folder ? Based on the docs, I think it is. - Is there some way to use API to persist a file in
/data
folder ? If so, what is the link to the documentation ? - Otherwise, how would you recommend to complete this task ? I mean, the task is using another user to store a file that is persistent across executions of the same container.
Thanks in advance
UPDATE
Yesterday, I created a separate routine with rsync
to copy the file to /data/session.json
. This is my workaround for now.
