Home Assistant (5.11) Supervisor (2021.02.6) NUT (0.6.2) running on NUC
Eaton Powerwave 9130 ran excellent until last major upgrade, I receive this error in NUT addon when starting:
Network UPS Tools - BCMXCP UPS driver 0.31 (2.7.4)
RS-232 communication subdriver 0.20
Unable to open /dev/ttyS0: Operation not permitted
Current user id: root (0)
Serial port owner: root (0)
Mode of port: 0660
Things to try:
Use another port (with the right permissions)
Fix the port owner/group or permissions on this port
Run this driver as another user (upsdrvctl -u or ‘user=…’ in ups.conf).
See upsdrvctl(8) and ups.conf(5).
ls -la /dev/ttyS0
crw-rw---- 1 root audio 4, 64 Feb 12 12:58 /dev/ttyS0
groups root
root bin daemon sys adm disk wheel floppy dialout tape video
I think the serial port needs to be in the dialout group for my NUT addon to access my UPS via serial cable.
what is the linux OS username your HA supervised is running under? I haven’t used that flavour since “hassio” and the username was homeassistant , but that might of all changed now.
anyway, get a login or ssh, as root
usermod -a -G audio,dialout <username>
e.g.
usermod -a -G audio,dialout homeassistant
but if root is the username, then it’s not permissions because root has full access to /dev/ttyS0 , more likely that is the wrong device name/doesn’t exist/kernel modules not loaded.
