Hello everyone,
This is a new install of Hassio on an Ubuntu host. On a large number of addons I get errors similar to the ones below:
Visual Studio Code Addon:
INFO code-server v1.1156-vsc1.33.1
INFO Additional documentation: http://github.com/cdr/code-server
INFO Initializing {"data-dir":"/data/vscode","extensions-dir":"/data/vscode/extensions","working-dir":"/config","log-dir":"/root/.cache/code-server/logs/20190706110036300"}
INFO Starting webserver... {"host":"127.0.0.1","port":"8443"}
WARN No certificate specified. This could be insecure.
WARN Documentation on securing your setup: https://github.com/cdr/code-server/blob/28c93612e63fde62fbb470e3f2265f81da1bac19/doc/security/ssl.md
WARN
WARN Launched without authentication.
INFO
INFO Started (click the link below to open):
INFO http://localhost:8443/
INFO
INFO Starting shared process [1/5]...
[21:00:36] INFO: Starting NGinx...
nginx: [emerg] open() "/proc/1/fd/1" failed (13: Permission denied)
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Portainer:
[21:05:13] INFO: Starting NGinx...
nginx: [alert] detected a LuaJIT version which is not OpenResty's; many optimizations will be disabled and performance will be compromised (see https://github.com/openresty/luajit2 for OpenResty's LuaJIT or, even better, consider using the OpenResty releases from https://openresty.org/en/download.html)
I have SSH-ed into the container and tried chown root /proc
and restarted the VM and HassIo but I still have the same error. Does any one have any ideas on how to fix it?
