I’m running HASS in a Proxmox VM and have been routinely running out of space due to backups getting larger, mainly from the habitual running of updates and the backup requirements from that. As such I figured it was about time to just have the backups go onto my NAS directly (already have appropriate mirrors set up with Google Drive).
I created a network storage share for backups, trigger it, can see it processing and creating the tar.gz files with the expected user (all_squash, only exposed to HA ip) but I consistently get the following error from the supervisor.
24-01-09 16:56:30 ERROR (MainThread) [supervisor.utils.json] Can't write /data/mounts/nfs_backups/tmpu84zym4u/backup.json: [Errno 13] Permission denied: '/data/mounts/nfs_backups/tmpu84zym4u/tmpwqu6hih0'
24-01-09 16:56:30 ERROR (MainThread) [supervisor.backups.manager] Backup 6d63bf1d error
File "/usr/src/supervisor/supervisor/utils/json.py", line 36, in write_json_file
with atomic_write(jsonfile, overwrite=True) as fp:
File "/usr/local/lib/python3.11/contextlib.py", line 137, in __enter__
return next(self.gen)
File "/usr/local/lib/python3.11/site-packages/atomicwrites/__init__.py", line 169, in _open
with get_fileobject(**self._open_kwargs) as f:
File "/usr/local/lib/python3.11/site-packages/atomicwrites/__init__.py", line 186, in get_fileobject
descriptor, name = tempfile.mkstemp(suffix=suffix, prefix=prefix,
File "/usr/local/lib/python3.11/tempfile.py", line 341, in mkstemp
return _mkstemp_inner(dir, prefix, suffix, flags, output_type)
File "/usr/local/lib/python3.11/tempfile.py", line 256, in _mkstemp_inner
fd = _os.open(file, flags, 0o600)
PermissionError: [Errno 13] Permission denied: '/data/mounts/nfs_backups/tmpu84zym4u/tmpwqu6hih0'
File "/usr/src/supervisor/supervisor/backups/manager.py", line 240, in _do_backup
async with backup:
File "/usr/src/supervisor/supervisor/backups/backup.py", line 345, in __aexit__
write_json_file(Path(self._tmp.name, "backup.json"), self._data)
File "/usr/src/supervisor/supervisor/utils/json.py", line 40, in write_json_file
raise JsonFileError(
supervisor.exceptions.JsonFileError: Can't write /data/mounts/nfs_backups/tmpu84zym4u/backup.json: [Errno 13] Permission denied: '/data/mounts/nfs_backups/tmpu84zym4u/tmpwqu6hih0
If I change the network share to a share and SSH in to home assistant CLI I can create files mimicking the structure completely fine, so it doesn’t seem to be a permission issue? But then the logs quite clearly state that it is?
Any ideas on what could be the cause here?
/srv/nfs4/home-assistant-backups 192.168.x.x/32(rw,wdelay,root_squash,all_squash,no_subtree_check,fsid=3,anonuid=1000,anongid=1000,sec=sys,rw,secure,root_squash,all_squash)
