Persistent button state from ESP Home relay switch
Hello!
I have an old home alarm that I partially integrated into Home Assistant. With the help of an ESP8266 as well as a relay and a remote control, I have now managed to control the alarm from the HA.
From the buttons of the remote control, I have soldered cables to the relay to be able to simulate button presses like a finger.
Now I have two buttons in the home assistant switch.arm_house and switch.disarm_house from ESPHome. Every time you press the button in HA, the relay is triggered and the status goes from on to off.
Now to the mint part, how do I get the on/off buttons to show permanent status? I want that when the button alarm on should show on all the time and then we press the next button off, the first should go to off again.
ESPHome Code
switch:
  - platform: gpio
    pin: 25
    icon: "mdi:shield-lock-outline"
    turn_on_action:
      - switch.turn_on: relay1
      - delay: 0.5s
      - switch.turn_off: relay1
  - platform: gpio
    pin: 26
    icon: "mdi:shield-lock-open-outline"
    turn_on_action:
      - switch.turn_on: relay2
      - delay: 0.5s
      - switch.turn_off: relay2
Home Assistant fronted code
color: rgb(3, 169, 244)
color_type: card
entity: switch.arm_house
show_state: true
state:
  - color: green
    value: 'on'
tap_action:
  action: toggle
    entity_id: switch.arm_house
type: custom:button-card
color_type: card
entity: switch.disarm_house
icon: mdi:shield-home
show_state: true
state:
  - color: red
    value: 'off'
tap_action:
  action: toggle
    entity_id: switch.disarm_house
Thanks in advance
Patric
You need to use a single template switch for your arm/disarm. Or you can do it the way you have now and add switch.turn_off: actions for the opposite switch.
Hi Daryl,
Single template is out of you knowledge, do you mind to share some code?
With adding another swith.turn_off: action should this not then trigger my secondary relay switch and then cause alarm to turn off again?
