Persistent notification inside alert section
Hello! Someone know if inside the notify section is it possible to add a persistent notification???
(without create an automation related to this alert…)
f.e.:
  battery:
    name: Battery is Low
    entity_id: binary_sensor.alarm_battery
    repeat: 5
    notifiers:
      - fra_phone
      HERE I WOULD ADD A PERSISTENT NOTIFICATION
Thanks a lot
Kind of. Alerts only take ‘notify’ components. persistent_notificaiton is not a notify component.
But, you can create a notify.restful to generate persistent notifications for you.
Just copy what they did. Create the restful notify component that simply writes to persistent_notification and use that in your alert list.
thanks a lot man!!!
From that topic it looks like you wont have to use that method once 0.118 is released:
hi! i’m using 0.116 in this moment…
could you explaine to me the changes/implemenation??
thanks a lot
When 0.118 is released it is very likely that persistent notifications will be used exactly like any other notify service. So no need for the work-around.
thanks a lot!
Is this implemented yet? I can’t seem to use it:
- platform: persistent_notification
throws me an error:
Platform error notify.persistent_notification - No module named 'homeassistant.components.persistent_notification.notify'
