I tried to setup person presence using Android app, but it doesn’t work and I saw error below in the Developer Tools. The configuration.yaml doesn’t contain anything about device tracker. There is no /config/logs in the file area. So, how to fix this?
Restarted HA, still error.
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
# database
recorder:
db_url: !secret mariadb_url
# cloudflared
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
persistent_notification.invalid_config
Invalid config
notifying message: The following integrations and platforms could not be set up:
- [device_tracker](https://www.home-assistant.io/integrations/device_tracker) ([Show logs](/config/logs?filter=device_tracker))
Please check your config and [logs](/config/logs).
title: Invalid config
friendly_name: Invalid config
