Persistent notification
Title of this post may be confusing. I am able to receive notification on my android phone. But If receive several notifications, it will only display the last one.
Is there a way to display all notifications until I cleared them?
Another option would be to use persistent notification. But how to receive a notification when I have a persistent notification? Is there an option in the native home assistant application?
please show YAML examples of what you are sending,
use the native element: https://companion.home-assistant.io/docs/notifications/notifications-basic/#persistent-notification
I use node red to send my notification.
I receive a notification from Jeedom, and I forward my notification to my phone.
The JSON is basic:
    "message": "{{payload}}"
That’s not enough to have any insight into what you are doing…
Then… Apologies… shouldn’t you be asking on a jeedom forum? Ha can’t control what NR or Jeedom do to your phone so notification list? Or maybe it can m I’d ask Jeedom not HA users?
The builtin notification for HA happily spams me auth entries when I give it too many things to tell me. :sweat_smile:
We may (are likely) misunderstanding you due to the lack of information. Please describe in DETAIL what you’re doing and HOW
Sorry, Indeed I was not clear in my explanation.
I started to use HA a couple of day ago. And my objective is to migrate my whole installation that currently run with Jeedom, to HA.
I use MQTT to communicate between Jeedom and HA.
When Jeedom has a notification, I send the message to HA through MQTT. I just want to send this message to my android phone, and this is what I do with a small flow wit red node.
It works well, but I want this notification persistent, meaning I want it to stay on my screen until I clear it. Actually the notification is replaced by the next one.
are you sure only 1 notification is visible and you dont see a group that you need to pull down? as you are not using the tag attribute the notification should not replace and new ones will post next to them. The OS may group them together if group is not set.
what notification action are you using? the one provided by the app?
I did some tests and you are right, all my notifications are here. Thank you for your help
